No head casting #s
Old Jun 7, 2005 | 03:25 PM
JaizRed's Avatar
Car: '83 Camaro Berli | '86 T/A WS6
Engine: 5.7L | 5.0L
Transmission: TH-700R4 | TH-700R4
Axle/Gears: 3.08 Drum | 2.73 Disc
No head casting #s
I've been trying to figure out which heads I have on my 350, but it seems that the casting #s have been ground off on both heads. The only numbers I can find are two small oval stamps on each side on the head, one with "F207" and the other with "21" and then "GM 38" stamped beside the pushrod guides. I checked the front of the heads also for #s but the only thing I could find there was "MRC" and "PHX C" just below that. Is there -any- other way I can figure out which heads these are??
Old Jun 7, 2005 | 03:32 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Not trying to offend, but you did pull off the valve covers and look, right?
The reason I ask is because you mention every other part of the head except under the valve covers.
Old Jun 7, 2005 | 03:50 PM
JaizRed's Avatar
Engine: 5.7L | 5.0L
Eh.. That's where the GM 38 and the F207 121 came from.
Old Jun 7, 2005 | 05:30 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Most SB chev heads have a identifier cast on the end of the head. What does your identifier look like?
Post a pic if possible. and a pic of the combustion chamber too.
Old Jun 7, 2005 | 05:58 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
F207 = the casting date; the 20th day of the Fth month (the 6th, June) of a year ending in 7
Could be this
14039121...81-86...305..........Truck
But it's hard to say, the dates are out of range.
People grind off casting #s when they're trying to cheat in racing, or screw somebody over in a sale. Not a good sign.
Old Jun 7, 2005 | 06:25 PM
JaizRed's Avatar
Engine: 5.7L | 5.0L
If they were cast in a year ending with a 7, I'd say they're from 77, probably about the same year as the block.
I'm not pulling the heads just to find out what the chamber looks like. I tried to get a picture of the front of the head but they all turned out sheetty.
What I can tell you is that the heads have the "right angle" identifier. Mortec says: 3947041....69-70...302/350......"Right angle" casting identifier, 64cc chamber, accessory holes, good HP head ---- 3947041X...69-70...302/350......"Right angle" casting identifier, 64cc chamber, 165cc intake port, accessory holes, good HP head
Old Jun 7, 2005 | 10:34 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Not sure when it started, but later model heads also have the last 3 digits casted on the bottom of the runner...might be able to get a small inspection mirror under there with a flashlight and see.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
92projectcamaro
Jan 18, 2016 08:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
z28guy134
Sep 1, 2015 11:50 PM
