TPI Heads
Old Aug 31, 2001 | 10:50 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
TPI Heads
How much better are 1986 IROC 305TPI heads then my stock 1992 LO3 heads?
Old Sep 1, 2001 | 09:54 AM
ttt
Old Sep 1, 2001 | 10:09 AM
Vader's Avatar
BC,
Do you have a casting number from your LO3 heads?
Later,
Vader
"Get UP - Drop the bombshell!"
Adobe Acrobat Reader
Old Sep 1, 2001 | 10:32 AM
nope dont got one but they are stock LO3
where can i get the casting number
Old Sep 1, 2001 | 11:26 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
86 TPI heads are 416 casting. I forget the casting # of TBI heads. TBI uses the "swirl-port" design, which puts a giant blockage in the intake path to promote re-mixing of the air and fuel, since, like in a carb motor, the fuel has a tendency to separate out from the air at low velocites. This of course makes them inferior for anything that requires unobstructed flow, but promotes better low-end torque with the lean mixtures required for emissions compliance.
The 86 heads aren't particularly good, but they are one of the better 305 heads. However they have perimeter-bolt valve covers and early-style intake bolt holes, unlike TBI engines.
ICON Motorsports
Old Sep 1, 2001 | 05:16 PM
Are you sure that 86 heads have center bolt valve covers? I thoght that 87 and later had them and the 86s had perimeter bolt pattern
Old Sep 2, 2001 | 01:34 AM
BahamutRS's Avatar
I have a set of 305 TPI heads I was going to put on my L03...but I decided to forget it and put on Torquers when I have a little more cash. It'll push me close to 300 HP without the juice on, that's for sure. I am gonna sell these 305 TPI heads.
1992 Camaro RS (Auto) 5.0L TBI
Performance mods
NOS (125 HP shot)
Dynomax cat-back exhaust
Hedman headers
K & N open element/ X-Stream lid
MSD 6A ignition
LT1 camshaft
Soon to be installed:
Edelbrock intake manifold
3.42 rear axle
B & M 2400 RPM stall torque converter
Transgo shift kit
Moroso Blue Max plug wires
Torquer heads
Audio
Sony Xplod CDX-M610 head unit
Pioneer 2-way 4x6 front speakers
Pioneer 3-way 6x9 rear speakers
12 inch Pioneer VCCS PRO subwoofer
QLogic sealed box
Kicker ZR360 amplifier
Lightning Audio 1 farad capacitor
Other
Macewen White Faced Gauges/Shift overlay
A-pillar gauges (Phantom oil pressure, Air/Fuel)
180* thermostat
Window Tint
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Sanjay
Aug 12, 2015 03:41 PM
