starting problem no sounds
Old Jun 8, 2005 | 09:10 AM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
Transmission: 5 Speed
ok so my cars been workin fine but yesterday it just wouldnt start at the store..i have a resistor soldered in to bypass my VATS in the key..been workin great..but now theres no sounds, security light turns off whats wrong???
is there a way to check my starter relay?
Old Jun 8, 2005 | 09:46 AM
formula2fast's Avatar
Car: 87 Pontiac Firebird Formula
Engine: 355 SBC-Thats all I can say or they will break my legs.
With a test light go down to the starter and put it on ground and the purlpe wire (s terminal). have someone crank the car. if the light lights up, then it is the starter or solenoid. if it does not light up, then it is your relay, your wiring, or your VATs
Old Jun 8, 2005 | 11:25 AM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
ok i got it to start once dont kno how just did..but then i turn it off n try starting it about n hour later n nothing? what relays could it be and does it sound like a relay?
Old Jun 8, 2005 | 05:54 PM
89Z's Avatar
89Z
Car: '89 IROC Z
Engine: TPI 305
No sound means most likely a bad starter solenoid. Common problem on these vehicles, but luckily a fairly easy and inexpensive fix if you do it yourself.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
