overheatin
Old Jun 8, 2005 | 01:51 PM
slammed_z's Avatar
Car: 1985 camaro
Engine: 305 H.O
Transmission: auto
overheatin
well i installed my new z28 gauges...and it turned out my temp gauge wasnt even hooked up from the hole time i owned the car,so i got it hooked it up..and within 40 mins of hwy driving,it went to the red zone..so i changed the thermostat,did a rad flush..i thought it was better,but its still doing it...any ideas? i dont have the black under the car rad cooler thing..never came with the car...but does it really help that much?
Old Jun 9, 2005 | 10:11 AM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
yes it helps when u have the air dam under ur car. it deflects air into ur radiator. definatly get an air dam.
Old Jun 9, 2005 | 12:06 PM
91wtROH17's's Avatar
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
Without that piece under you car you WILL overheat!!! Put one on and problem solved. If you have to, just shave it down abit, cause your car is so low, try to keep as much of it as you can though!
CaliChevyLover
Jul 22, 2009 10:20 AM
LEONELB
Aug 6, 2007 12:46 AM
theratdude64
Aug 1, 2006 09:26 PM
Irock1985
Jul 18, 2006 10:37 AM
