No current to 1,3,5,7 injectors?
Old Sep 1, 2001 | 05:24 PM
RBMZ28's Avatar
Car: 87 IROC (low 12's)
Engine: 400 sbc .040 over
Transmission: 700r mod
hey guys,need major help here!have no current to 1,3,5, and 7 injectors.have changed computers,and checked wires and fuse.
any suggestion would be appreciated.this is crazy!
87 IROC WITH 409(.040 OVER400) MINIRAM,NOS(125HP)TRICK FLOW PORTED HEADS,C.C.CAM,FLOWTEK HEADERS,CUSTOM PROM,MODIFIED 700R TRANS,2400 B&M CONVERTER,3.73POSI REAREND.
LOOKING FOR THE 11 SEC. ZONE.current ets.12.39@114 mph
Old Sep 1, 2001 | 05:33 PM
Vader's Avatar
RBM,
There are two injector fuses - one for each bank.
If you don't have 12VDC at the left bank of injectors, you either have a failed INJ1 fuse or a bad connection along that orange wire.
If there is 12VDC present at the left bank, the injectors are not being grounded by the ECM. The left bank connects to the ECM at terminal D15 through a light blue wire in the harness. The ECM provides the ground path for the injectors to complete the circuit.
Later,
Vader
"Get UP - Drop the bombshell!"
Adobe Acrobat Reader
[This message has been edited by Vader (edited September 01, 2001).]
Old Sep 2, 2001 | 03:10 PM
RBMZ28's Avatar
thanks vader i'll give it a try!!!
92projectcamaro
Jan 18, 2016 08:00 AM
BAMiller
Sep 14, 2015 06:38 PM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
greenyone
Sep 2, 2015 03:39 PM
