Found oil on 2 spark plugs but not much
Old Jun 8, 2005 | 08:18 PM
IonNight's Avatar
Car: 1986 Iroc Z
Engine: Truck 305 /Bored .30 Flat Pistons/ Crane Cam
Transmission: Corvette 700R4
Is this a valve cover gasket leak???
Also could this cause a running lean code 44?
I have been tryin to narrow my problem down since the beginging and its been one thing after another.
**Brief summary**
Car was running rich
Changed bad fuel pressure regulator
Car started running lean right off the bat
Found oil on spark plugs when replacing
still running lean after codes reset
Old Jun 12, 2005 | 10:28 AM
Vader's Avatar
Was the oil on the threads and outer insulator, or on the electrodes and inner insulator?
External oil can be from a leaking rocker cover. Internal oil is more likely from a leaking intake, which might also explain a lean condition.
Old Jun 12, 2005 | 11:59 AM
PneumaticTire's Avatar
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
Does the vehicle blow blu smoke even when its warmed up especially under some throttle? If so, they you have blowby possibly happening as well, from either worn cylinder rings, or scored cylinder walls.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Feb 28, 2016 03:33 PM
92camaroJoe
Aug 13, 2015 06:07 AM
