0.6 Cam Lift, Do i have enough room?
Old Jun 9, 2005 | 12:14 PM
DashHavoc's Avatar
Car: 82 Z28 T-Top
Engine: 010 Nickle Block/ Spare LS1
this is my engine setup for my 82 Z28
Stroker...
350 4 bolt main, its a 010 Nickle Block
Bored 60 over
Scat 9000 series 400 Block Crank
4340 forged Eagle H-Beams 6" Rod
crane 1.6 roller rockers and guide plates
Fully Ported/Polished Heads, Cast 492 #
I have with 2.055 and 1.6" valves with double springs
MSD Pro Billet Distributor, with MSD blaster 2 coil
and crane cams hi6 ignition box
port matched victor jr
Holly Dbl pmpbr 850 cfm
The pistons are 10.3 compression KP "Hyperpatethic" 0.60 Flattops
I am getting a custom roller cam made specific to my needs so i can keep a good powerband.
The lift will be 0.600 on the intake and 0.62 on exhaust
The question i have is will I have enough clearance with that size of cam lobe?
And how can i check?
-Matt
http://www.cardomain.com/ride/292897
Old Jun 9, 2005 | 12:17 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
put some clay/puddy on the piston and turn the motor over by hand after torquing down the head. Measure the distance at the thinnest spot of the puddy.
Old Jun 9, 2005 | 01:13 PM
ede's Avatar
ede
you need to dummy it up and check, my guess is you have pleanty of room, but you need to check to know for sure
Old Jun 10, 2005 | 09:30 AM
katman's Avatar
Car: 91 Z28
Engine: 468 ci
Transmission: thm 350
I'd be more concerned with cam to rod clearance. Might need a small base circle cam.
Old Jun 10, 2005 | 11:32 AM
DashHavoc's Avatar
Car: 82 Z28 T-Top
Thanks for all your answers
and thanks katman for mentioning cam to rod clearance... i wouldve never thought about that.
After a bit of reasearch i will require a 1.786” nominal journal diameter, so ill really have to get that custom grind cam
Thanks!
-Matt
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
