CTS sensor same as IAT sensor???
Old Sep 2, 2001 | 04:25 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
I went to my local parts store the other day and asked the guy for an IAT for my new motor. He pulled a box that said CTS and said that was the right part. I haven't had a time to look at the old one, but does anyone know if this is correct?? It just sounds funny to me.
Riccioli Performance Motorworks
--RPM Racing--
Getting there.....383 with Super Ram, Bosch 24# SVO's, MSD, Edelbrock 58 mm TB, 700R4 tranny, Eibach springs, Koni 12 way adjustable shocks and struts, and more!! Now let's pray it runs when it's all back together!!!!
Old Sep 2, 2001 | 04:37 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Not even close. The IAT, aslo known as the MAT, goes in your intake hose/air filter box. The Coolant Temp. Sensor goes in your Intake Manifold. Both serve very different functions. What does the sensor look like? Does it have a brass cylinder-type thing on the end? Or is the tip of the sensor plastic?
-Dan
-1990 3.1L RS
-Mods? no
-Slow? yes
-Currently collecting parts for T5 swap
Old Sep 2, 2001 | 05:14 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Funny that should come up, the two I have on my car are interchangeable. Same sensor.
"Question with boldness even the existence of a *** ; because, if there be one, he must more approve of the homage of reason, than that of blind-folded fear."
-Thomas Jefferson
Old Sep 2, 2001 | 05:25 PM
Guest
Guest
Posts: n/a
There is an IAT that has a different part number, but the only difference is the sensing element is exposed on that one. The resistances of both sensors are the same, and on most cars the sensor is the same part.
Old Sep 2, 2001 | 05:53 PM
Car: 89 IROC-Z
Engine: 383
So then I would be ok running that one for sure?? I don't want to have to take my Super Ram off again once it's installed.
Old Sep 2, 2001 | 06:07 PM
JETHROIROC's Avatar
I've always used the same Delco part # for both on mine. Hope this helps.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley module, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Streetdampr, Ruger P95DC, hot wife, new oil filter, !cats, !TB.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old Sep 2, 2001 | 06:14 PM
Engine: LH0 3.1L
<font face="Verdana, Arial" size="2">Originally posted by madmax:
There is an IAT that has a different part number, but the only difference is the sensing element is exposed on that one. .</font>
Huh, that's the one i have. The tip is plastic and you can see the little resistor inside. My CTS is just solid copper or brass. Guess i learned somethin new......
-Dan
-1990 3.1L RS
-Mods? no
-Slow? yes
Old Sep 3, 2001 | 02:33 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
There is an IAT that has a different part number, but the only difference is the sensing element is exposed on that one. The resistances of both sensors are the same, and on most cars the sensor is the same part.</font>
Max is correct. The best GM MAT for TPI cars is the one used in the LT1s. It is designed for air and is much quicker reacting. That is why TPIS's relocation kit uses the later MAT.
Relocating the MAT is raises its own issues. For SD you must alter the eprom to or it ruins the calibration (GM didn't design the eprom for these cars with a relocated MAT).
For MAF it seems to be handled different depending on the type of MAF system you have. On $6E, it only seems to affect the EGR. It does not seem to have any effect on the fuel/spark (However, if you get into "Source Code", then you make it do anything). But, this is another level again.
On GN's, it does seem to affect timing but not fuel (without altering the Source Code).
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
