Timing Problem. HELP!
Car: 1991 firebird formula
Engine: 5.8
ok so i put in a 327 at idle the timing has to be at least 36* advance for it to start do you think it is a cam to crank or a distributor issue or something else?
Car: 1983 Pontiac Trans AM
Engine: 355 chevy
Transmission: 700R4 Built
Axle/Gears: Built 10 bolt 3.73 gears
the springs that hold the weights in the distributor could be too strong but yet again 36* is a ton on the average I think your only supposed to have 36 degrees total without vacuum!
