Knocking and fire
Old Jun 10, 2005 | 01:23 AM
Sunny RS's Avatar
Car: 89' RS
Engine: 5.0
Transmission: slipping 700r4, soon probuilt
Knocking and fire
My car is knocking. My oil pressure is flying all over it burys way past 60 then drops down to like 30. I looked under my car tonight and this part was on fire right above the oil filter and next to the Oxygen sensor can anyone help me out or at least tell me what that part is? theres i think 2 wires coming outta it and it goes into my block
Old Jun 10, 2005 | 01:31 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Sounds like the oil pressure switch.
Old Jun 10, 2005 | 09:47 PM
Sunny RS's Avatar
Car: 89' RS
Engine: 5.0
Ok so i was driving the car today and the oil just droped and my car car died cant get it started? could that be the oil pressure switch?
Old Jun 10, 2005 | 11:00 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The oil pressure switch powers the fuel pump if the fuel pump relay fails. If both of them failed, you could have the problem you describe. It sounds like you might have even bigger problems though.
Old Jun 11, 2005 | 04:51 PM
Sunny RS's Avatar
Car: 89' RS
Engine: 5.0
like what bigger problems? spun rod bearing and others
Old Jun 11, 2005 | 07:07 PM
Sunny RS's Avatar
Car: 89' RS
Engine: 5.0
i jumped the fuel relay found out that was blown also the oil switch set on fire. If the oil switch is non working could that cause a knock?
Old Jun 11, 2005 | 08:25 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, but if the oil pressure switch was working but the fuel pump relay wasn't and the car shut down because of no oil pressure, that would certainly cause a knock.
Old Jun 12, 2005 | 10:54 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
Could also be the Oil Pressure Sensor for the dash gauge. Camaros had I think three locations for this sensor. My friend's 91 RS v6 MPFI has it screwed in at the base of the oil filter.
Anyone else think this looks like:
1.) Bad FP relay
and
2.) Failing Oil pump
RedLeader289
May 28, 2019 01:47 PM
RS Reaper
Oct 17, 2018 07:52 PM
bigjay89gta
Oct 15, 2015 08:04 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
efiguy
Sep 27, 2015 01:30 PM
