Spark Plugs
Old May 31, 2005 | 12:59 PM
Hummer's Avatar
Car: 1986 Z28
Transmission: 700-R4
Spark Plugs
Time to replace the damn things - might as well grate my knuckles on concrete...
Anyways, the question everyone asks when standing in front of the wall of plugs...which ones? I'm not going for the Bosch Platinum +4 anytime soon...I just need your slightly above average plugs - I'm not sure I remember what I've got in there now - car is still in storage...any advice?
Thanks.
Old Jun 2, 2005 | 01:00 AM
FORMULA355TPI's Avatar
Car: 88 FORMULA / 88 IROC
Engine: 355 / 355
Transmission: T5 / TH400
Axle/Gears: 10 Bolt-3.73 / 9"-3.90
NGK part number - UR4 gap at .040" . If you are using any type of power adder .035" these are good baselines you can fine tune for the best tune from there
Old Jun 2, 2005 | 02:12 PM
csx2002's Avatar
Car: 1983 Trans Am
Engine: 350 crate engine
Transmission: t-5
I am a big fan of the platinum +4's, i use them in all of my cars. :-)
Old Jun 2, 2005 | 04:51 PM
firebird45331's Avatar
Car: 86 Firebird, 2002 Monte Carlo, 91 v
I wouldn't use bosch platinums as anything other than a catfish weight.
Old Jun 2, 2005 | 04:56 PM
btw what headers are you using? full length? shorties?
Old Jun 2, 2005 | 08:09 PM
Hummer's Avatar
Car: 1986 Z28
Whether or not the Bosch's are good - my engine isn't running smooth enough nor do I have the cash to fork out on sparkplugs that cost twice as much as everything else
I have short - tube headers - I'm looking forward to working around them...I might have to remove them anyways to "fix" an exhaust leak, so that may make things a little easier.
Old Jun 3, 2005 | 03:32 AM
i had bosch platinums and I had to clean them about every 300 miles. They'd foul up quicker than anything I've ever seen. Those headers pretty good though?
Old Jun 4, 2005 | 02:46 AM
vejatabul's Avatar
Car: 1988 gta
Engine: 5.7
Transmission: turbo 350
that means you have the incorrect heat range. a plugs job is to simply live in the chamber and provide spark and remove heat. if your plug does not live in its enviornment then it is the wrong plug for the motor. you cannot tune with a spark plug, spark plugs do not affect the way the motor runs, they only live in the enviornment. if they are the right plug for your motor, then you can tune by looking at the plug, but changing to a different heat range will not make the motor have a hotter spark or any other type of mythical pfm.
Old Jun 4, 2005 | 07:56 AM
Engine: 355 / 355
veja- I suggest you get your information correct before you try to help anyone else with incorrect statements. You CAN tune with your spark plugs ie. if you have a detonation problem they may be too hot of a heat range, standard tip plugs may provide less preignition than extended tip designs, and plug gap makes a HUGE diffrence in the kind if mixture you can send into an engine without losing spark. By the way last I checked spark plugs were inanimate objects they have never "lived" and unless there is some kind of dramatic improvement in technology they probably never will.
Old Jun 4, 2005 | 09:05 AM
i used the spark plugs bosch recommended for my car and they fouled. Wasn't a matter of having the wrong plug. It was the plug they said I needed. I have plain bosches in my volvo and couldn't be happier with them, but their platinum plugs where the electrode sits flush with the insulator is trash
Old Jun 4, 2005 | 05:38 PM
vejatabul's Avatar
Car: 1988 gta
Engine: 5.7
that is not tuning. having the incorrect heat range plug would means it is the wrong plug. why dont you go read up on it and then make assumtions? if you were to have a ridge on one of the pistons that caused a heat spot and preignition, then removing it would not be tuning the engine. the same with extended reach plugs. you know what i mean by "living" in the motor, to exist without failure. what does plug gap have to do with spark plug design? you can change the gap on a plug. but you would not be changing the plug. all of your info is irrellavent to what i said. look at it again and this time try to understand instead of making incorrect assumtions.
Old Jun 4, 2005 | 05:45 PM
who are you saying had the incorrect heat range? Mine was correct and they still fouled. I switched to another platinum tipped plug with the same heat range and I didn't have any problems
Old Jun 4, 2005 | 05:55 PM
jasman19's Avatar
Car: RED 1986 IROC-Z28
Engine: 350 5.7L
Transmission: TH 700R4
Axle/Gears: 3.23 10 Bolt
I use champion spark plugs and haven't had a fouling problem. They are #RV17YC. Ever since I've been using them I haven't had any detonation problems, hesitation, or anything for that matter. Its what I recommend but I also heard the NGK plugs are good too.
Old Jun 4, 2005 | 05:59 PM
I originally had NGK's in the volvo. They did ok. I usually use AC Delco
Old Jun 4, 2005 | 06:09 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
could be many other things going on though. and from the sounds of it you DID get the wrong plug if they are fouling out
plugs that foul out are doing so because they aren't getting hot enough to burn the stuff away.
just because they said that is what your car uses doesn't mean it's the end all of that. old cars run different and sometimes use different things
Old Jun 4, 2005 | 06:20 PM
if I got the wrong temp then they were in the wrong box. I don't even have the car anymore. It was a Daytona with a 2.5. I've known other people who used the Bosch Platinums and had the same problems. I switched plug brands to cheap autolite platinum junk and never had a single problem after that.
Old Jun 5, 2005 | 09:50 PM
Engine: 355 / 355
veja that is how is changing plug styles to better suit your needs not tuning? If a person were to use a car as a not so daily driver and hardly (if ever) go to full throttle then you might want to use a hotter plug in their car. In the same aspect if you are beating the snot out of a car and it spends little time without the blades wide open then you may not need to go with such a plug because cyl pressure/temp will be high enough to keep them clean.. In my opinion that is the very esscense of tuning, changing a car to perform best in the environment it "lives" in.
Old Jun 7, 2005 | 03:33 PM
vejatabul's Avatar
Car: 1988 gta
Engine: 5.7
the spark plug does not change the way your motor runs. diff driving styles and enviornments might need a different plug so that it will not foul or burn, but changing the plug does not change the way the motor runs, except if it fouls or burns. just go to ngk's website and read.
Old Jun 7, 2005 | 04:14 PM
Engine: 355 / 355
So then based on your theory if you run a delco r45ts then a ngk ur4 is the exact same plug and the design difference has no bearing on performance. What about ground strap design? What about a grooved or non-grooved electrode? What about extended or standard tip design? What about the way a platnum electrode will actually glow in a high compression or forced induction engine? Does this mean you have some delco r45ts' a couple ngk ur4's and maybe some bosh platnums of the same heat range all together in your own engine? I would hope not. In other words, you read too much..
Old Jun 8, 2005 | 12:53 AM
vejatabul's Avatar
Car: 1988 gta
Engine: 5.7
how about you assume too much. you assume an r45ts and a ur4 are the same heat range when the manufacturer says they are not, they are only close. using different materials is going to change conductivity. but would you use a ngk ur4, ur45,ur5, or a ur55 in your motor? what plug is used and works best is the plug to use, and putting a different heat range than what the motor needs will not help power.
you dont "tune" a motor by changing the plug, you simply would be putting the more acceptable plug in. you would be putting the correct plug in, and thats what there is, the right plug, and the wrong plug and a whole lotta grey area.
do you believe that all your cylinders run the same a/f? its compramise. now go find something else to talk about that you something know about and leave the theroy to politics.
Old Jun 8, 2005 | 08:55 PM
Engine: 355 / 355
Alright this is getting old I give up. You'd better do the same i think your spark plugs are hungry they need to eat if you want them to continue to live in your engine...
Old Jun 9, 2005 | 03:25 AM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Last time I changed my plugs, I threw in a set of Autolites AP26. got them cheap at Wally's world. They work just fine.
I also have a set of Rapidfires that I'm going to use next time.
If you're going to change your plugs, change the cap and rotor as well. And inspect your wires.
Old Jun 9, 2005 | 06:40 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Tip design, gap, heat range all change the way the motor runs, all effect fueling and timing tables, etc.
Perhaps on a stock GTA, the 'mfg recommended range' is fine, but for those of us running 500-600hp, we need to 'tune' with our plugs.
Thats why aftermarket heads recommend a "starting point", not a specific plug to use.
-- Joe
Old Jun 11, 2005 | 02:31 PM
vejatabul's Avatar
Car: 1988 gta
Engine: 5.7
tell me exactly how tip design, heat range and gap affect how the motor runs.
if you dont know exactly how they affect "fueling and timing tables" then you are just regurgitating **** you have heard from some other idiot who heard it from another. dont fight ideas that go against your previously logical assumptions, you do not have all the information to create such informed theroys.
Old Jun 11, 2005 | 03:38 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
What exactly would you like to know? Would you like to discuss how the delco 45's responded with timing on my motor last season, or when I switched to the 43s and was then able to ramp out timing sooner? Or maybe just change plugs around and see how the different heat ranges affect closed loop corrections.
Oh and if you switch to a colder plug, you need less AE too.
You do prom tuning right? Ever tune a 500 hp motor? 600 hp? Spend hours at the track trying various maps and plugs until you got it 'just right" ?? Didn't think so.
-- Joe
Old Jun 11, 2005 | 04:39 PM
firebirdjones's Avatar
plugs
I agree with anesthes and formula355tpi, you can tune with your plugs. I have experiemented with this on my 70 Firebird and also on my 72 454 chevelle. I have played with heat ranges, gaps, extended tips, and I have also experimented with grinding the ground strap back to expose some of the electrode. I have found some things that worked for me. My Firebird is very sensitive to detonation,,,by switching to a colder plug and going to a standard tip instead of the extended tip, I was able to remove alot of the detonation. I have found the biggest improvements on plugs by grinding the ground strap back to expose some of the electrode, this made a slight improvement on my chevelle. Also indexing the plugs when installing them is a known practice that has been around for many years.
If you don't believe any of this, spend some time at some of the Nascar tracks, those guys are scraping for every last hp they can get, and they do alot of experimenting with plugs to do it. Those guys know what they are doing, pulling 800 hp from 358 cubes is a tall order. Ever see a plug from a Nextel Cup engine? I have seen some where they have removed so much of the ground strap it would be impossible to even gap the sucker any more, this is what gave me the idea to experiment with this. Can't argue with the Nascar engineers, they know there is some horsepower to be found in the spark plugs. As far as plugs for a stock engine? Well I am partial to AC Delco, I would just run a stock heat range for the application and go with it. Just my experiences, hope this helps, Larry.
Old Jun 12, 2005 | 06:08 AM
CAH383's Avatar
Car: 86 Camaro Z28
Engine: 5.3 LM7
Transmission: TH400
Don't know anyone who likes the platinums, sorry!! AC Delco for me.
Old Jun 12, 2005 | 07:54 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Why doesn't this topic ever go away. The horse's corpse is already decaying and yet the poor thing is still getting beat.
Tuning means, generally, doing anything to improve the resultant output (what you are tuning for). If you think that increased goals such horsepower or fuel efficiency is not an improvement... As for the micro-definition in our world contextually, it typically means getting your chosen combination to run optimally. Much like jet selection, plug selection, and modification, is tuning. No buts about it.
As for plugs...
Originally posted by Red Devil
Contextually...
Multi-prong plugs are worthless in our motors. At best they are a waste of money, at worst they will impede the flame front in the combustion chamber.
If you don't like doing plugs often, Bosch Platinum are fine (single plain old platinum) SO LONG AS YOU DO NOT RUN AN AFTERMARKET IGNITION!! Not so good for reading the plugs either, but longevity is great. Same with all the funky metal plugs.
Bosch copper core (Cu conducts better than all those funky metals), AC Delco, Champion all the 'regular' plugs are fine as well if you feel you don't mind changing them more often, or you need to read the plugs.
Wires... depends on the ignition. Aftermarket ignition will typically call for thicker/better wires. Stock ignition, you can use stock-type wires.
On a 305 TBI... anything is fine.
Old Jun 12, 2005 | 11:01 PM
Engine: 355 / 355
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Jlanz55
Sep 9, 2015 09:09 AM
90formulaVortec
Sep 8, 2015 12:42 AM
89 formula TPI
Sep 7, 2015 11:06 AM
