i seriously need help
Old Sep 3, 2001 | 09:43 PM
91firebirdfosho's Avatar
Car: 1991 firebird formula
Engine: 383
Transmission: th350
Axle/Gears: 3:73 posi
i put headers,cam,and manifold and it wont rev past 2000 rpms and its spits and sputters when i gas it. its a 305 tbi i need a list of what it can be. does it need more fuel or what it just doesnt idle right and it wont rev past 2000 help help help
Old Sep 3, 2001 | 09:44 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Is the dist in right.??
Whats the timing at??
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old Sep 3, 2001 | 09:56 PM
92fire-audio's Avatar
Sounds to me like your timing is off.. Check that first. Then check for vacuum leaks..
Did you degree the cam?
Did you reset the computer?
Old Sep 3, 2001 | 09:58 PM
Engine: 383
Transmission: th350
my uncle said the dis should be right and he timed it at 0 degrees i think does that sound right
Old Sep 3, 2001 | 10:01 PM
Engine: 383
Transmission: th350
would a vaccum line make it only rev up to 2000
Old Sep 3, 2001 | 10:33 PM
87RS402's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 91firebirdfosho:
my uncle said the dis should be right and he timed it at 0 degrees i think does that sound right</font>
Your uncle and my manual disagree. Try 6 degrees BTDC, ot 10 degrees. My manual has both listed for the 305 but goes by VIN not TBI or TPI.
