Wouldn't removal of the AIR system effect the O2 sensor readings?
Old Sep 3, 2001 | 05:13 PM
FormerOldsGuy's Avatar
The AIR system is injecting air (oxygen) into the exhaust manifold before the O2 sensor. Wouldn't the O2 readings change if the A.I.R. was removed because there wouldn't be extra air coming in? Or am I missing something here?
Old Sep 3, 2001 | 05:25 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Good question. I never thought of that. But that would seem to make sense. The AIR tubes are shooting air into the ex. manifold before the O2 sensor sees the exhaust.
If the computer is programmed from GM to take the AIR into account from the O2 reading, then it would seem that it would lean out the mixture quite a bit after you took out the AIR system. After all, it would think that it's running REALLY rich due to the lack of oxygen.
Anybody have any experience with this problem, or have we just thought up a "doesn't matter" situation?
AJ
Old Sep 3, 2001 | 05:45 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Yea you would think so but nothing happens.
BBT, im curious what the real deal is.
SSC
Old Sep 3, 2001 | 05:54 PM
Ozzy88GTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.0 TPI
Transmission: TH700-R4
The real deal on the AIR is that air is injected into the exhaust manifold or headers while the engine is still cold. At a certain coolant temperature (can't remember) the divert valve then swaps over to inject the air into the catalitic converter. The air is then no longer injected into the exhaust stream before the O2 sensor.
This is done to help burn the exhaust gas at the exhaust ports while the engine is still cold, and allows the cat to heat up before air is injected into it to let the cat do the burning of the "unburned hydrocarbons".
The O2 sensor during this warm up time will be in "open loop" so the computer does not really register a lean exhaust condition.
Old Sep 3, 2001 | 06:11 PM
JETHROIROC's Avatar
Ozzy is right, no air to the manifolds in closed loop.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley module, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Streetdampr, Ruger P95DC, hot wife, new oil filter, !cats, !TBC, !AIR.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old Sep 3, 2001 | 07:38 PM
UVA3rdGen's Avatar
sweet, I learned something today. I always wondered why the hell that box was there. Well used to wonder until I took the whole system off.
Old Sep 3, 2001 | 08:53 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Those guys are correct. That is the purpose of the "diverter valve". During Open Loop operation (O2 sensor ignored) the air is injected into the manifolds. Once Closed Loop operation is acheived, the diverter valve sends the air to the catalyst.
ON a side note, a failed diverter valve can set a code 44 (Lean Exhaust) because it can put air into the manifolds during closed loop operation.
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old Sep 3, 2001 | 11:09 PM
AJ_92RS's Avatar
<font face="Verdana, Arial" size="2">Originally posted by GMTech:
</font>
Cool. So what you are saying is that if I were to remove my AIR tubes going to the ex. manifolds, then my car would be polluting the atmosphere at start up, but once it reaches closed loop (and if I left it hooked up to the cat) then it would still pass emissions?
That's all I really want. Just to get rid of those damn tubes under the hood. I still want the cat to work correctly.
How can I leave the cat hooked up and still have the AIR running into it? Just bypass (and remove) the diverter and have the pump running to the cat at all times? Or would I have to leave the diverter in there and just plug the side that goes to the "used to be there" tubes?
AJ
Pac J
May 17, 2020 10:44 AM
meeklay812
Oct 1, 2015 03:46 PM
Giocio
Oct 1, 2015 12:20 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
