air bubbles???
Old Sep 4, 2001 | 02:10 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
air bubbles???
is it possible to get air bubble is the cooling system after replacing the heater core? also would this make my car run hotter? and how do u get them out??
thanx
Old Sep 4, 2001 | 02:38 PM
89BlwnRs's Avatar
Yes it is possible to get air in the cooling system, and yes, it can make a car run hot. In the little experience I have, they will usually work themselves out with time, but if you're overheating too much then I believe the proper way to bleed the system is to uncap the radiator and start the engine, allowing it to run until hot. This usually makes a mess, but it should fix your problem.
I hope this helps,
Jason
Old Sep 4, 2001 | 02:44 PM
87tpi420's Avatar
i have heard to loosen the hoses and let some coolant/water leak out and this helps to move air.
87 z28 bowtie aluminum 420small block dry sump crower lt. wt. knife edged crank oliver lt wt rods brodix track 1's super ram intake slp 1 3/4 headers accel dfi art carr 700 r4 3.42 gears ssm sub frame/ladder bars.....other parts on the way ,soon to be finished!! couple more weeks!!!
http://people.ne.mediaone.net/gdm
Old Sep 4, 2001 | 02:54 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
how long should i let it run for?? and how hot should i let it get? also what hoses should i disconnect???
Bubbajones_ya
Jul 6, 2024 08:32 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
edoff13
Sep 11, 2015 03:55 AM
scotrans am
Sep 5, 2015 04:26 AM
