Power Steering Question
Old Jun 12, 2005 | 09:39 PM
speedingpenguin's Avatar
Car: 1981 Chevy Malibu, 1987 Formula 350
Engine: 229 V6, L98 TPI 350
Transmission: TH350, 700R4
Axle/Gears: 10 bolt ???, 9 bolt 3.27 posi
Since i took the engine out almost half a year ago, i forget how it went. The fitting on the end of the hard line i know where that goes, but where does the other hose go to? Anyone have pics? Thanks
this is on an 89 formula BTW
Old Jun 14, 2005 | 10:01 PM
kboehringer's Avatar
Car: 1982 - Z28
Engine: 350 / CCC Q-Jet
Transmission: THM-700R4
Axle/Gears: 10 Bolt - 3.73
Power Steering Connections
Speedingpenguin,
I think I can help. Derek and I are converting our '82 style to a later model '86 and we have studied the routing on both units.
You said you knew where the High Pressure went, marked with an "H" in the photo.
Scenario #1 Your car is newer and this is probably it!
You have the extra cooling loop (bottom of pic). The fluid comes out of the steering box at L4 and is connected to the loop via L3.
The Fluid comes out of the loop at L2 and connects via a rubber hose and clamps to the back of the steering pump at L1.
Scenario #2
You do not have the extra cooling loop (bottom of pic). L1 connects directly to L4 via a rubber hose and clamps.
Hope this helped,
Kurt
Old Jun 15, 2005 | 12:04 PM
Thanks!
I found out where the line is supposed to go (Accidentally, and it left a nasty stain on the driveway, ooops ), so thats all set
Thanks for the help though!
MustangBeater20
Oct 29, 2022 09:20 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
redmaroz
Aug 16, 2015 11:40 PM
