e-brake
Old Jun 13, 2005 | 08:11 AM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
e-brake
Is it possible to adjust my e-brake? Right now, I have to pull the level as far back as it will go before I see the brake take effect.
Right now, the car has not been ran in over a year (doing the v6-v8 swap), could that have something to do with it? Can I adjust the cable somehow?
Old Jun 13, 2005 | 08:27 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
this thread will help.
https://www.thirdgen.org/techbb2/sho...=ebrake+adjust
Old Jun 13, 2005 | 08:44 AM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
ea. the adjustment is in the trans tunnel right above the driveshaft.. (common problem is when the e-brake cable pop out of the bracket and rub causing a wear ring around the driveshaft and making a grinding noise on bumps..) But anyhow.. You just turn the nut until it is where is needs to be.
After that is depends on whether you have a disc rear or a drum rear. The disc has by far fewer parts to fail....
Old Jun 13, 2005 | 11:28 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
My rear discs wouldn't work on matter what I did becuase of the brake recall. I got new calipers, bled the lines, got a new prop valve, now the car stops like it was designed to and the e-brake works.
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
jawzforlife1
Apr 25, 2002 03:36 PM
The Dirty Bird!
Apr 1, 2002 02:36 PM
stuart69427
Feb 22, 2002 08:38 PM
88transam5.0
Dec 19, 2001 06:58 PM
