Is this fuel line to close to hedder?
Old Jun 13, 2005 | 10:53 AM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
I just got done swapping from TBI to Carb, and this is the only way i could find to run the feed line, and i dont want it to be dangerous. heres the pic
Old Jun 13, 2005 | 11:22 AM
SPIKE's Avatar
Car: 86 CAMARO
Engine: 92-350 +.030
Transmission: 86-th400
witch line ? the one in the pic. looks like its laying on the header. not good ! looks like it could be straightened out to run along the valve cover then turned down. or the rubber line behind the alternator ? i dont like rubber fuel lines that close to the engine i would replace it with ss braided at least or metal tubing.
Old Jun 13, 2005 | 12:05 PM
brutalform's Avatar
If you are talking about the curled line coming off the fuel regulator, I think that one is safe.
Old Jun 13, 2005 | 12:43 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Sorry, i get a little dumb sometimes. Look at the picture again.
Old Jun 13, 2005 | 11:53 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Old Jun 14, 2005 | 12:01 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Looks like more than enough to me.
Old Jun 14, 2005 | 12:17 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
ditto
Old Jun 14, 2005 | 12:20 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Although, you might want to cut down on the amount of rubber hose you're using, and secure it a little better.
Old Jun 14, 2005 | 12:27 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
and as soon as you get the spare cash, put some braided line in, for insurance sake...
Old Jun 14, 2005 | 12:35 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I can vouch for the results of rubber lines going bad.....
But yea, they are ok. If you have some concern beyond suggestions that they are, put some heat wrap around them.
Old Jun 14, 2005 | 12:56 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
looks like that line runs right across the alternator mount.watch out for sharp edges!also,nylon zip-ties can keep things neat and tidy.vibration against anything can cut a line in short order!
Eric B
Old Jun 14, 2005 | 08:23 AM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
I may try the heat wrap then. Does anyone know of any other way to run those line? That was the best way that i could find
Old Jun 14, 2005 | 12:30 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Looks fine to me. TBI pump is not going to damage anything either so the rubber line is adequate.
Old Jun 14, 2005 | 01:53 PM
mw66nova's Avatar
Engine: 7.0L
rubber line will dry rot and crack and spill fuel all over those headers. braided line is the only thing i will use, period.
Old Jun 14, 2005 | 02:41 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
TPI lines are rubber and run the same pattern across
Old Jun 14, 2005 | 03:37 PM
jasman19's Avatar
Car: RED 1986 IROC-Z28
Engine: 350 5.7L
Transmission: TH 700R4
Axle/Gears: 3.23 10 Bolt
Don't see a problem with the line, as in the post above "thats the way the tpi lines are". If you're really worried about it cracking get some braded (like everyone else said) or you can get some high pressure rubber line from earl's. Used it on my car and have had no problems. In any case I think you're good and have nothing to worry about.
Old Jun 14, 2005 | 05:50 PM
mw66nova's Avatar
Engine: 7.0L
tpi lines are not exactly the same rubber hose. they are a high pressure rubber hose with a braided webbing inside them...kind like powersteering hoses.
Old Jun 14, 2005 | 08:39 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Don't expect to pass tech inspection a any dragstrips with that setup. That much rubber hose is very dangerous.
You can do better. Spend the money on new steel line and reroute it better. Rubber hose should only be used to join the steel fuel line together where it comes off the frame to the motor to allow for vibration. Shouldn't be more than 1- 2 inches at any joint.
Old Jun 14, 2005 | 11:50 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
looks fine to me too just secure it.
Old Jun 15, 2005 | 07:51 AM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
Definetely cut down on the rubber line, a cheap way to get rid of some of it is to use 3/8 brake line, you can buy a 3 ft. pice from a local parts stor for only a couple of bucks. If you have to tech the car he will probably bounce it. (12 inch max rubber line in fuel system) if i remember the rule book right.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
Kaweh
Aug 9, 2015 02:54 PM
