90 formula 350 TPI no start condition
Old Jun 13, 2005 | 11:03 AM
drptop70ss's Avatar
Car: way too many
Engine: 283s to 454s
Transmission: autos and sticks
Hope someone can give me some help.. Just picked up a 90 forumula with the 350 tpi engine and it will not start, just turns over. Previous owner thought it was the ignition module, so first thing I did was check for spark and I have spark. Next checked for fuel pump working, I can hear it prime up when I turn the key on so I assume it is working. Put some raw gas in through the throttle body and still no fire. Pulled the #1 plug and checked rotor position and it was off some, but not enough that I couldnt rotate the distributor to make it up, lined it up at #1 with the timing tab at 6 deg advance on compression stroke. So I should have spark at the right time, compression is good, but possibly there is a fuel issue?. When I pulled the #1 plug it was fuel soaked, and when bumping the starter over to find the compression stroke gas was literally spraying out of the hole. I pulled a few other plugs and they were not fuel soaked, had a slight fuel smell to them but not dripping like #1 was. I didnt put that much raw gas in the intake but possibly it was from that, either way no start or even a caugh from the engine. Could this be a fuel pressure issue? How do I check it? I found the schrader valve on the pass rear of the fuel rail and there is what looks like a valve stem connector on the rail also. How do I check fuel pressure and what should I be seeing for values? Right now I think the starter is shot also as the engine is turning over very slowly. Would engine cranking speed have an effect? Also FWIW I swapped out the ignition module even though I had spark just in case there was a bad signal to the ECM but no change. I verified I still have spark after the swap. Anyone have any ideas? I have done some computer car troubleshooting but very little with third gens and fuel injection. Thanks for any help or ideas!
Old Jun 13, 2005 | 02:26 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I imagine if you cranked it for a long period of time: 1) your battery is about dead or 2) you didn't allow time for the starter to cool down between the cycles.
I would recharge the battery first. Normally starters have a tag right on them saying if you try to use them at 10.5 or below volts you can damage the starter.
While you're at it I would consider checking the oil to make sure it hasn't be soaked with fuel.
You can check the fuel pressure with a gauge you should beable to find at the local Auto Zone or similiar parts store. Stock should be around 43 give or take a few, but I do not know if that is the same for starts.
Old Jun 13, 2005 | 03:57 PM
drptop70ss's Avatar
Car: way too many
Thanks for the reply..starter was pretty much dead when I picked up the car, even with the battery on charge I could only get half a spin out of the engine, then a pause, then another half spin. Enough to verify spark and some quick troubleshooting but not a very fast crank. Tried another battery, no change, so I will replace the starter. Supposedly when this engine was running before the refusal to start it was smoking pretty bad, so I am wondering if high fuel pressure was dumping fuel into the engine. Still not sure why I dont get even a sputter out of it, I think the VATS is ok since the engine does crank but I dont have noid lights yet to check the injectors. I will pick up a noid light kit and a fuel pressure kit. From reading the archives I see I have to disconnect the vac line from the schrader valve when checking pressure, but where does the fuel pressure guage hook up to? I dont see any ports other than the valve that looks like an air valve on a tire stem.
Old Jun 14, 2005 | 06:58 AM
Engine: 383 SBC
Normally you disconnect the vac line from the fuel pressure regulator (near the back of the intake) not the valve. The gauge will go off the valve.
Vintageracer
Jan 10, 2020 05:33 PM
okfoz
Mar 9, 2017 02:35 PM
theshackle
Mar 5, 2017 06:37 PM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
