roller rocker ques
roller rocker ques
I am collecting parts for the 350 buildup. It is going to be a zz4 clone. I was thinking about using 1.5's on the intake and 1.6's on the exhaust side. Is anyone running this, opinions, suggestions? Should I run the 1.6's on the far exhaust ports(1,2,7,8)or all? This is on a TPI motor with a ported plenum and Accel intake, stock runners for now, $$ for slp runners later.
Jeremy
WE WILL MISS YOU #3
92 Z conv
5-spd B&M shifter
home-made ram air, air foil, headers, no cat, TB bypass, kevlar pads, slotted rotors, BMR panhard, alston SFC, 3.42's, Edelbrock STB, 350 in the works
Jeremy
WE WILL MISS YOU #3
92 Z conv
5-spd B&M shifter
Car: 4
Engine: 6
Transmission: 5
There is no benefit that I know of to downgrading any of the rockers in that application. IMHO you should run the 1.6s on all of them. OF course, if it's really a ZZ4 clone, you'll need some different valve sprimgs, of a larger diameter specifically, to accomodate the lift; so the heads will require some work if they're regular stock aluminum L98 heads.
ICON Motorsports
ICON Motorsports
the springs are good to 525 lift and are new. The stock rockers off the 305 TPI are 1.5's correct? That is what I was going to reuse if I didn't buy a set of rollers. the heads have the work done already as well as some breathing help. If I go to 1.6 all around, the lift will be to high on the intake side. So wil I be better off geting new springs and the 1.6 or going 1.5 all around in this situation.
Jeremy
Jeremy
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
It's not just springs that you'll need for extra lift. Make sure the valve stem has been modified to take the extra lift also. If it hasn't the the spring retainer will hit the top of the valve stem. You'll also need to do a mockup assembly to check how much valve to piston clearance you have. The 1.6 rockers could give too much lift for the pistons. You need a minimum of .100" between the pistons and the valves when open. If the block isn't decked then there's usually not a problem but you need to check all the measurements anyway.
My big block just came back from the machine shop last week. .091" clearance on the intake and .139" on the exhaust. I could go with more lift on the exhaust but absolutly no more on the intake. Actually I could go from the 1.7 rockers on the exhaust to a 1.8 rocker and be right on the money for clearance but I'm not buying another set of rockers just to use 1/2 of them.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.546
Car: 4
Engine: 6
Transmission: 5
What heads? Are they really going to be the ZZ4 (L98) heads? If so, it's probably worthwhile to step up to the 1.6s... the 1.6s and 1.5s are the same price after all.... If you're going to run the actual ZZ4 cam too, that means that even with 1.5s you'll need to get the spring pockets cut, so again, there's no penalty, cost or otherwise, to using the higher lift.
ICON Motorsports
ICON Motorsports
I have alum. heads off a vette and I will be running the real zz4 cam. This is truly going to be a learning experience.
Jeremy
WE WILL MISS YOU #3
92 Z conv
5-spd B&M shifter
Jeremy
WE WILL MISS YOU #3
92 Z conv
5-spd B&M shifter
KO1
16
Oct 15, 2015 05:00 PM
