replacing fuel pump-what else needs changing?
Old Sep 4, 2001 | 11:03 PM
1989 5.0 tpi's Avatar
Well I've decided to go ahead and replace my fuel pump (after investigating all the other possibilities). What else should I order at the auto parts to be replaced at the same time? Is there a sock/filter, seal/gasket, or anything else?
Old Sep 4, 2001 | 11:15 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Yes, replace the sock.
The o-ring will come with the new pump.
Do yourself a favor and buy a GM part. I've seen aftermarkets fail within a year. I'm not saying they will fail, but I've had better luck with OEM parts.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old Sep 5, 2001 | 09:41 PM
Jza's Avatar
Jza
Yeah, don't scrimp on the pump. It's not something you want to do more times than necessary. I replaced the tank itself in my 89. The 92 tanks have a better designed plastic sump to prevent starvation in sharp cornering when low on fuel. $30 from a yard.
Old Sep 6, 2001 | 07:52 AM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Engine boy is right. Get OEM pump. Do not get it from a "YARD". Buy it new and also get a new fuel filter and clean out the gas tank.
Old Sep 6, 2001 | 07:57 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
are the walbro ones good? (i think thats the company)
92camaroJoe
Jul 29, 2023 07:57 PM
specialized
Jun 18, 2022 09:26 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
