Would an LTI's intake fit on a L98????
Old Sep 5, 2001 | 12:08 PM
LottaBallsCamaro's Avatar
Self explainitory.
I'd rather be historically accurate than politically correct!
Old Sep 5, 2001 | 12:26 PM
Vader's Avatar
LBC,
Yes, and no.
The intake would fit, but some of the bolt holes won't align. The rear coolant crossover would be open to atmosphere, and you'd have to machine a hole for the distributor, since the LT1/4 and L99 engines have the distributor on the crankshaft end near the timing cover. There would also be no exhaust passages for the EGR.
Other than that. the intake would fit between the heads perfectly.
If you want an aftermarket LT1-style intake for your L98 or other older SBC, look at the Accel Mini-Ram systems. They are in essence a clone of the LT1 system.
Later,
Vader
"Click - Click - BOOM!"
Adobe Acrobat Reader
Old Sep 5, 2001 | 12:30 PM
Vader's Avatar
BTW - Just a warning about some of the people who might post on this board...
Some people might be compelled to ask why that flag isn't upside-down, in flames, torn, with holes, or white - in the interest of historical accuracy, of course.
I just wanted to point out that some people might post those kinds of messages, so be prepared.
Later,
Vader
Old Sep 5, 2001 | 04:06 PM
FlameRedMetallic's Avatar
as for the stars and bars, heritage, not hatred my friend.
86 IROC-Z
305 TPI
700R4 W/ shift kit
3.23 gears
T-Tops
maroon with gold stickers and rims/ black interior
43,000 miles
flowmaster exhaust, edelbrock headers, gutted airbox, converter, and MAF, K&N filters.
soon to come are 3.73 gears and subframe connecters.
Old Sep 5, 2001 | 04:45 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Im not complaining and hell, I was born in Ohio! :P
1983 Firebird
TH700R4 Auto
Small Block 400
LG4 ECM, Intake, Carb, Distributor, etc.
Soon to be non-computer.
Clarion Head Unit 45X4
2 Pioneer 400W 12" Subs
Third Gen Performance
"A four cylinder is half an engine."
"Ponies can run, but birds can fly..."
Old Sep 5, 2001 | 06:31 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
How the hell would you know if its upsidedown or not?
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old Sep 5, 2001 | 09:17 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
The stars point down.
Old Sep 5, 2001 | 09:18 PM
Car: Death Mobile
Engine: 666 c.i.
And I'm a Canadian!
Another triva question: How can you tell if the Union Jack is upside down?
[This message has been edited by Glenn91L98GTA (edited September 05, 2001).]
Old Sep 5, 2001 | 09:50 PM
Vader's Avatar
Glenn,
...or better yet, what's heads or tails on a twoonie?
I've heard it described as "Queen Elizabeth with a bear-bottom", but I still don't know which way is up.
And if the Union Jack is upside-down, the beefeater who is holding it is standing on his head and smiling (the ONLY time they appear to be smiling). Or would that be a Mountie in your case?. At least they smile some times.
And what's with those new quarters? Some of them have TWO heads on them.
LBC,
I TOLD you some people might post that way, but I'm surprised at the restraint of some of our members. I guess there's hope after all...
Old Sep 6, 2001 | 01:56 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
<font face="Verdana, Arial" size="2">Originally posted by Vader:
</font>
Getting back to the topic of this post, TPIS makes the MiniRam, not Accel, who makes the SuperRam.
Yes the LT1 will fit on a small block chevy, but it wont bolt up or be usuable without extensive modification.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Old Sep 6, 2001 | 06:36 PM
Vader's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Kevin91Z:
</font>
Kevin,
Thanks for the correction. I guess I got my "Rams" confused...
You're right about the LT1 intake, but I've heard of people cutting a distributor hole in them to accomodate a "regular" distributor. I've never personally seen one, though.
Later,
Vader
Old Jun 20, 2015 | 01:29 AM
kevins88's Avatar
Re: Would an LTI's intake fit on a L98????
what about the other way around////
Old Jun 20, 2015 | 12:59 PM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Nothing like dredging up a 14 year old thread. But, I'll play along.
By "the other way around", I assume you mean to put a TPI intake on an LT1.
Read this, LT1 intake conversion , and do the opposite.
  1. Distributor - either keep the LT1 oil pump stub and plug the intake, or drop in a standard distributor.
  2. Bolt pattern - mill and drill to fit. The 4 corner bolt holes are purported to be correct. The 4 middle, and other 4 "next to the corner" bolt holes need modification.
  3. Coolant - I am guessing you don't have to do anything, because the LT1 intake does not touch the coolant.
  4. Fuel lines - stock TPI would probably work.
So, it really comes down to adapting the intake-to-head bolt pattern.
Or you can find an Accel LT1-Super Ram base... intake bolt pattern
lt500r55
Sep 1, 2021 01:30 PM
theurge
Aug 21, 2015 12:46 PM
TheExaminer
Aug 19, 2015 10:07 PM
matthew911
Aug 12, 2015 09:38 AM
