Intake Bolt Pattern
Old Oct 29, 2010 | 05:38 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Intake Bolt Pattern
I was scouting my Lingenfelter manifold to get an understanding on what I'd be looking at to polish the runners, and the intake bolt pattern caught my eye.
It looks different than a typical TPI manifold, particularly the two middle pairs of bolt holes. They look wider apart. What am I looking at here? Is this a Vortec manifold? Centerbolt?
Old Oct 29, 2010 | 05:54 PM
Car: 1985 Z28
Re: Intake Bolt Pattern
OK, just read that Vortec heads don't have center bolt holes. So we are looking at a cetnerbolt style manifold, right?
I was planning on getting some new heads for the motor anyways. So instead of having the manifold bolt pattern redone, could I just buy a set of centerbolt heads? Will centerbolt heads bolt right up to a block that originally had perimeter bolt heads?
Old Oct 29, 2010 | 06:28 PM
injdinjn's Avatar
Car: 1986 Grand Prix TPI
Transmission: 200 4R
LT1.
Old Oct 29, 2010 | 06:30 PM
Car: 1985 Z28
Originally Posted by injdinjn
LT1.
I'm not doubting you but why they make an LT1 manifold for a TPI? LT1 WAS the intake (Among other differences).
Shouldn't I be able to have the manifold bolt pattern re-drilled and the old holes plugged up by a muffler shop?
Old Oct 29, 2010 | 07:11 PM
Drew's Avatar
It's so you can bolt a Super Ram on an LT1.
Old Oct 29, 2010 | 07:17 PM
Car: 1985 Z28
Which bolt holes would need to be re-drilled for a set of perimeter bolt SBC heads? All of them?
Old Oct 29, 2010 | 07:29 PM
Drew's Avatar
Do a search for the LT1 intake conversion.
Old Oct 29, 2010 | 08:00 PM
Car: 1985 Z28
Can someone post a link to a thread/website regarding this? The search function isn't being very helpful. I keep finding either an LT1 intake for sale. Someone with a "question" or a dead end website.
Aside from the bolt holes, I am concerned about how just about everything else on the manifold will match up IE runner ports and coolant passages and EGR (EGR will be deleted but I want to make sure nothing is left open).
What am I looking at to make this work?
Old Oct 29, 2010 | 08:18 PM
Drew's Avatar
Jump over to the "alternative port EFI intakes" sub-forum... https://www.thirdgen.org/forums/alte...t-efi-intakes/
Click "search this forum" at the upper right, type in "LT1 intake" without the quotes and hit enter. Jump back to about the 2nd or 3rd page and start reading. It was a hot swap for about 10 minutes, and whatever has to be done to make a LT1 intake match up is gonna be necessary to make a LT1 super ram base fit.
Personally, I'd sell the thing. It's gotta be more uncommon then the one you're looking for, therefore, it's probably worth more then the standard old school intake.
Take a look at this thread... https://www.thirdgen.org/forums/alte...am-vs-tpi.html
Old Oct 29, 2010 | 08:39 PM
Car: 1985 Z28
If It's as easy as having the center holes redrilled, I'm not trying to sell it since I bought it with the cast finish already sanded away and that would be a HUGE PITA for DIY (To do this to the plenum which is far less complicated took 3 weeks between work and family). However, at the bottom of this post a guy shows a pic of an LT1 superram base and he says that they welded up the T-stat and Dist holes. Both are open on mine however and don't show any signs of ever being plugged.
The only thing I can tell you about this manifold is that I bought it off Ebay already polished. It was used as a show piece and has NEVER been fired. This claim in re-enforced by the lack of watermarks in the T-stat passage and carbon on EGR passages/oil marks on the intake passages.
Old Oct 30, 2010 | 03:07 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by FireDemonSiC
I However, at the bottom of this post a guy shows a pic of an LT1 superram base and he says that they welded up the T-stat and Dist holes. Both are open on mine however and don't show any signs of ever being plugged.
Lingenfelter used the reg TPI base casting for LT1's.
Just drilled the intake pattern different.
A LT1 has no coolant to intake so most LT1 owners just put a cover plate on the thermo hole and a frost plug in the unused dist hole
Old Oct 30, 2010 | 03:15 PM
Car: 1985 Z28
LT1 vs an early style SBC, which holes are different? Just the center 2 sets or all 12 of them?
Old Oct 30, 2010 | 04:52 PM
Drew's Avatar
http://www.lt1engine.com/tech/lt1-to...-bolt-pattern/
http://www.google.com/search?hl=en&s...=Google+Search
Old Oct 30, 2010 | 06:31 PM
Car: 1985 Z28
WOW! That looks so easy I'm gonna do it myself. The only thing I'd worry about though is the method he used for plugging the holes. Sure JB Weld is some GREAT stuff, but over time with the temperature having such large fluctuations over the seasons and the heat from engine operation, not to mention the pressure that is being applied to some of those plugs from the bolts because the new holes were drilled so close, I just don't think it would be up to the task.
Wouldn't it be a much better idea to take the manifold to a muffler shop and have the old holes plug welded?
Old Nov 1, 2010 | 07:29 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Maybe , but you might get distortion so you would have to get the intake faces machined square
I would be going to a shop that specializes in alum fab and welding that know what they are doing; not the local muffler shop
Old Nov 1, 2010 | 10:12 PM
Drew's Avatar
JB Weld is a terrible idea. It's bad enough trying to find a muffler shop that can weld mufflers. Welding aluminum is a little more specialized. I wouldn't expect it to be cheap. I'd still sell it and buy what you need instead.
1992 Trans Am
May 10, 2023 07:19 PM
beastin91rs
Oct 9, 2015 07:38 AM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
hokis
Wheels and Tires
Aug 26, 2015 04:21 PM
