Cam Help please
Old Nov 2, 2010 | 11:52 AM
tonyh406's Avatar
Cam Help please
I'd like to get some opions on the cam with this setup, since I'm a little weak in understanding cam shafts. I will be creating custom programming for this setup, I'm starting with AUJP and working from there. Basically I want to make sure the cam will work with everything else.
Here is what I have:
Small Block 350 ('98 Pickup)
Vortec Heads
TPI ('92 Firebird)
This is going into an '86 Fiero that weighs between 2,800 and 3,000 lbs
CAM:
COMP Cams 08-304-8
Hydraulic Roller Tappet, Advertised Duration 266/276, Lift .500/.510
Cam Style Hydraulic roller tappet
Basic Operating RPM Range 1,400-5,400
Intake Duration at 050 inch Lift 210
Exhaust Duration at 050 inch Lift 220
Duration at 050 inch Lift 210 int./220 exh.
Advertised Intake Duration 266
Advertised Exhaust Duration 276
Advertised Duration 266 int./276 exh
Lobe Separation (degrees) 114
Tony
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
