Oh ***, I never want to datalog again!
Old Jun 15, 2005 | 09:11 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Big datalog problems...
Did I screw something up, or did something just happen to die at the same time?
I connected the ALDL cable. Opened datamaster, set up the com ports and vehicle type. Then I turned the key foward, hit test com, and it said successful and recognized my ecm. I could see my tps voltage...etc
I go to start it, it fires right up, vroooooom, then shuts off in 2 seconds (multiple tries). I unplug everything, same thing. I connected the A and B terminals, only a code 12.
Ideas?
Old Jun 15, 2005 | 09:26 PM
Car: 1988 IROC-Z
Engine: 427 SBC
Ok, I just unplugged the battery for 20 min, and it fired and ran fine.!?!?
Then I hooked up the aldl cable again, winaldl was green, giving me sensor data, go to start it, same thing.
Old Jun 15, 2005 | 11:05 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
i don't use datamaster so i know nothing about it.
does it die if you stay on the gas petal some, say what would normally have it up around 2000 RPM?
Old Jun 15, 2005 | 11:29 PM
Car: 1988 IROC-Z
Engine: 427 SBC
It dies in 2 seconds no matter what. It is def ecm related. It dosent even try to stay running. After I have the ALDL hooked up, I have to reset my ecm so the car will start. After the reset, it runs great until I try to datalog again.
Old Jun 15, 2005 | 11:48 PM
DENN_SHAH's Avatar
i have never ran across anything like that, it kind of sounds like something in Datamaster is turning the VATS on, but then they didn't use VATS in 88 as far as i know.
i see you asked over in DIY Prom,.. maybe someone will have an answer for you over there.
its a really strange problem.
maybe give 1 of the other data logging software apps a try & see what they do.
Old Jun 15, 2005 | 11:53 PM
Car: 1988 IROC-Z
Engine: 427 SBC
It does it with winaldl, datamaster, and tuner pro. I can get data when the key is foward from all of them, but it wont run again till I reset the comp.
Old Jun 16, 2005 | 12:04 AM
DENN_SHAH's Avatar
maybe its something with your data cable, is it 1 you bought or did you make it yourself?
is anyone up there that has a car you can try it on?
Old Jun 16, 2005 | 12:13 AM
Car: 1988 IROC-Z
Engine: 427 SBC
This is what i'm using..
http://www.moates.net/product_info.p...products_id=49
http://www.moates.net/product_info.p...products_id=50
Old Jun 16, 2005 | 01:32 AM
DENN_SHAH's Avatar
i know you have probably already tried, but does the ALDU1 cause the same thing in both the other 2 positions besides the down=short position?
does it flash the check engine light in the shorted position with the key on engine off?
Craig sells some good stuff. if nothing else, e-mail him about this.
probably not whats wrong, but there may be a driver or some other problem causing this.
ULTM8Z
Oct 2, 2015 01:25 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
ezobens
Aug 19, 2015 10:29 PM
bamaboy0323
Aug 15, 2015 07:20 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
