82cc aluminum heads, possible?
Old Jun 15, 2005 | 10:47 PM
WhiteLightnin83's Avatar
Car: 83 Z28
Engine: Mild 383 Stroker
Transmission: B&M TH400 with shift kit
Axle/Gears: 3.73 Limited Slip
ok, i built my motor originally just as a raw power motor, no forced induction or juice. i'm very happy with it, but as it goes with horsepower... never enough. my newest idea is to put a supercharger on the car, to do so i'll need to lower the CR since my pistons are 10.9:1 dynamic CR and thats obviously way too high for forced induction. so what i'm wondering is can i buy such a thing as 82cc aluminum heads,(that flow well obviously) to lower my CR to about 8.5:1. i need some ideas... i'd really like to run like 10-12 lbs of boost through it, but we'll see what comes of this post... thanks in advance!
Old Jun 16, 2005 | 09:03 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
I would say depending on the head yes. Starting w/ a 78cc chamber, most head porters should be able to get a good 3-4 ccs extra in the chambers. I talked to Brian Tooley at TEA one time and he said he could get about 4 ccs on a LT1 port fairly safely... and more on others depending on the casting.
Old Jun 16, 2005 | 11:44 PM
Car: 83 Z28
ok, so if i start with aluminum 78cc heads(who makes that size?) and i can have them ported and actually have CCs added? how do they do such a thing, and what kind of money am i lookin at for a port job like this? thanks so far!
Old Jun 20, 2005 | 03:19 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
there are a couple companies. I don't remember off hand though. AFR does IIRC. Its not techinally a port job, b/c its not porting the runners, but just massaging the chambers to open up the cc...
midge54
Dec 27, 2019 04:14 PM
italiano67
Aug 31, 2015 06:04 PM
bdads
Aug 24, 2015 06:01 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
