Thanks for Starter Help
Old Sep 7, 2001 | 07:18 PM
DaveV85iroc305TPI's Avatar
Yesterday I went to start my car and it just kept cranking even when I took the key out. Luckily I was at home and was able to get some tools to disconnect the battery to get it to stop. I was ready to replace the ignition switch until i did a search on this board with my symptoms. Sure enough someone else had the same problem and it turned out to be the starter. So I looked at it and found that was still stuck in the engaged position. Then I needed to find out how to get it out and found a another post with detailed instructions including a tip that said to pull the solenoid off first then pull it out. You guys really saved me a lot of headaches, I was able to replace the broken starter myself so hopefully by posting this it will help some one else.
My 85 Iroc
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
