how long for this??
Old Sep 7, 2001 | 03:49 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
how long for this??
how long would it take to put in an aluminum driveshaft??? can i do it my self or should i just pay someone to do it??
Old Sep 7, 2001 | 04:07 PM
Ehelmsin's Avatar
It will take about 15 min... its cake! Jack up the car, undo the 4 bolts holding the driveshaft to the rear, slide it out of the tranny... do the reverse to put in the new one.
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Jack up the car, put jackstands under rear axel.
Put a pan under the rear seal of the trans
unbolt 2 of the 4 bolts going into axel, pop trans into neutral turn driveshaft 1/2 way. Remove other 2 bolts going into axel. Removing the 2 U caps holding in your u-joints.
push driveshaft forward, use a stout screwdriver to place between the U-Joint and reciever to break free.
drop rear of axel and pull out, the trans will drip some.
to install reverse removal.
the bolts are 10mm head if I remember right.
87 Formula Yellow/Black
5.1 TPI Automatic
Baer 12" brakes 4 wheels, KYB AGX Adjustable Shocks & struts, Custom Leather interior, WAAAY TOO MANY MODS TO LIST
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
Old Sep 7, 2001 | 07:41 PM
Vader's Avatar
OK has the right idea. Definitely use the jack stands, and use a drip pan if you want a cleaner job.
Don't forget to repack the U-joints on the replacement shaft before you install it, and check the trans oil level and watch for leaks when finished.
While the shaft is out and you're right there, check the input pinion shaft on the rear end for excessive play.
Later,
Vader
"Click - Click - BOOM!"
Adobe Acrobat Reader
z 28 jari
Sep 14, 2021 10:03 PM
Formula8r89
Sep 22, 2015 04:24 PM
corey8084
Sep 17, 2015 02:56 PM
Street Lethal
Sep 7, 2015 01:09 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
