Anybody have the Holley AFPR for thier TPI?
Old Sep 6, 2001 | 08:55 PM
mbarland's Avatar
I just finished putting it on and the cap won't unscrew far enough to bring the pressure any higher than 20psi. The cap hits the plenum.
Anybody have a similar problem or is the 85 TPI different than other years? I'll have to wait until tomorrow before Holley tech support can get bitched at.
85 TA, 305 TPI, AT, T-Tops,
Russet Mettalic over Gold
My T/A's Page
Old Sep 6, 2001 | 08:57 PM
breathment's Avatar
did u unplug the vacum connection? and wut is the PSI with the stock unit, maybe u have a fuel problem. or maybe u got a bad Holley PFR.
- David
88' GTA 350 MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT
Old Sep 6, 2001 | 09:06 PM
rezinn's Avatar
You're supposed to screw it IN to raise the pressure, and it shouldn't even be able to go below about 36psi. I think you have problems elsewhere.
Old Sep 6, 2001 | 10:11 PM
mbarland's Avatar
The old AFPR was broken, but worked well and put out 47psi. I didn't check it without the vacuum, cause something seemed wrong right off. I'll take another look at it tomorrow, but there is still almost no adjustment that can be physically made.
Old Sep 6, 2001 | 10:15 PM
mbarland's Avatar
Took a look at it now, cause this is bugging me.
Ok, without vacuum it's the same thing.
Old Sep 7, 2001 | 02:43 AM
Omar's Avatar
Have you tried screwing it IN yet?
1989 IROC-Z 5.7L
NOS 5151 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Sep 7, 2001 | 08:25 AM
mbarland's Avatar
Yes I did, but I thought it was in all the way. It seems I cross threaded the cap. Oops.
Took a fresh look at it this morning and saw it looked crooked. Guess I was kinda tired last night....
Old Sep 7, 2001 | 04:26 PM
breathment's Avatar
so is everything ok?
Old Sep 7, 2001 | 10:45 PM
mbarland's Avatar
Yeah seems to be, just another case of me being an idiot.
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
355tpipickup
Aug 19, 2015 10:02 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
