how to epoxy a hydraulic lifter to make a solid lifter for checking pushrod length
Old Jun 17, 2005 | 02:52 PM
rsn932's Avatar
Exactly as the title says, how exactly do you fill an old hydraulic lifter with epoxy to make it like a solid lifter to check pushrod length? I've seen people say to do this, but I don't know where you are supposed to put the epoxy or anything. Any help is much appreciated.
Old Jun 17, 2005 | 03:39 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
It's much easier to remove the inners and replace them with a stack of washers to the same height of the inners.
Then you just drop the top of the lifter back in, on top of the washers, and replace the retainer clip.
The height of the inners need to be the same so you'll get an accurate length, but also so the top of the lifter doesn't shift around (side-to-side) and screw up your readings.
Surprisingly it's not too difficult to find washers that will work. Just take an empty lifter to the store with you and play.
Old Jun 17, 2005 | 03:46 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
When I made one, I shimmed it such that the cup the pushrod sits in was .030" lower in the hole to simulate the height of the lifter when adjusted. I just pulled some old junk out of my "magic bolt box" and played with it to get the correct height.
Old Jun 17, 2005 | 04:06 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
I tried the epoxy method, and it was trickier than I thought it would be.
If you put too much in there, you can't get it back together.
And if you don't use enough, then it breaks loose while you're checking and throws your measurement off.
I like the washer idea better.
Old Jun 17, 2005 | 04:38 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's even easier to just buy a couple of solid lifters.
Old Jun 17, 2005 | 05:00 PM
rsn932's Avatar
This is probably a dumb question, but does it work just the same if I used a press to pump up the hydraulic ones?
Old Jun 17, 2005 | 09:56 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I dunno...but I'd guess the cost of a single solid lifter would be less than epoxy...or so close it'd take all the guesswork out of it.
What's a no-name solid run these days? 6-8 bucks?
Old Jun 17, 2005 | 10:35 PM
Lo-tec's Avatar
I was talking about factory roller lifters...I haven't seen a solid replacement for those.....
Old Jun 18, 2005 | 01:19 AM
91Z28-350's Avatar
There is, it's not cheap though. Comp Cams @ Summit, about $400+ for a set of 16. I'm sure you could buy a pair separately, but it's not inexpensive for a one time use item.
sweet_87_iroc
Sep 25, 2015 10:01 PM
86White_T/A305
Aug 17, 2015 12:16 AM
cstrobel65
Aug 15, 2015 10:19 AM
rsrmoore
Aug 7, 2015 08:44 PM
guy76767
Aug 6, 2015 05:58 PM
