Problem w/ LPE 219 cam and stock distributor
Old Sep 7, 2001 | 11:39 PM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
Anyone have a problem making this work or is it us? The dist. just doesn't seem to go down all the way. Is a diff. gear needed w/ this cam?
89 IROC-To see mods go to: http://www.geocities.com/buckeyeroc
Old Sep 7, 2001 | 11:52 PM
rezinn's Avatar
I've never used an LPE cam but I would assume that the gear would be exactly the same.. have you tried moving the oil pump shaft around with a screwdriver to line it up correctly? Maybe put the dist. in another way?
Old Sep 8, 2001 | 10:14 AM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
I agree it sounds like you arent getting the oil pump driveshaft inline with the distributor.
I had to pull mine out a cople times to get it too work. You may have to take a long screw driver and turn the pump shaft till it lines up.
90 IROC
SuperRamed 406
Trickflow 23* heads
Old Sep 8, 2001 | 11:36 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
LPE cams are no different from any others in that regard. Your oil pump isn't lined up; pull the dist and turn it a little, and keep doing that until the dist drops in.
ICON Motorsports
Fanatic1074
Oct 3, 2022 05:57 AM
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
HoosierinWA
Oct 7, 2015 10:15 AM
Ranbo108
Sep 9, 2015 12:20 PM
