No start, whacked started, now it starts
Old Jun 18, 2005 | 03:41 PM
Abubaca's Avatar
...could this be a symptom of heatsoak from the headers? ...or since it started after I whacked it with a hammer mean the starter is going bad?
I know the hammer trick can work if the starter is going bad, but didn't know if it worked with heatsoak.
Old Jun 18, 2005 | 05:50 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
i have never heard of a heat soaked starter working from a hit with a hammer,... but anything is possible, but probably not likely. if you don't change the starter or get it rebuilt,.. keep the hammer with you.
Old Jun 18, 2005 | 05:53 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
A heat-soaked starter is a starter going bad.
Old Jun 18, 2005 | 08:09 PM
91blkta's Avatar
Car: 1991 Pontiac ta 5.0l 2005 pontiac gxp 5.3l ls4 dod 2003 GMC Envoy 4.2l
Heat soak just stops the starter from working till it cools down. When my father bought his 68 vet it use to happen all the time untill he bought a high torq starter. He useto poor water on the starter to cool it down, before he replaced it. Sounds like starter is going bad the hammer trick works for a while but you need a new starter.
Old Jun 18, 2005 | 08:26 PM
Abubaca's Avatar
I'm gonna get it rebuilt regardless.
I guess my question was more like should I get a heat shield when I re-install it. Since it doesn't sound like a heatsoak problem, I think I'll be OK without one.
Thanks!!
Orr89RocZ
Apr 25, 2016 08:28 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
perZ
Aug 15, 2015 01:17 PM
