protopline heads and TPI, cam question
Old Jun 18, 2005 | 05:16 PM
dharrison's Avatar
Car: 1968 chevy truck, 85 z/28
Engine: 355, 355
Transmission: 700r4, 350turbo
i have searched the forums and read alot of good input but not exactly what i want to know.
has anyone ran 200cc protopline heads on a 355 roller block with a modified TPI{ported edelbrock base, and SLP runners, 52mm TB, 24lb/hr injectors, AFPR} and LT4 hotcam.
is this the right cam for this? what springs would i need for this setup? what push rod length would i need with the 1.6 PRO MAGNUIM rockers on this setup? has anyone had any problems with this setup? do i need 1-5/8" or 1-3/4" headers?
Old Jun 18, 2005 | 09:26 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
I would go with the 180's and a comp xr264hr, the pro 180's flow nearly the same as the 200's.
Old Jun 18, 2005 | 09:53 PM
dharrison's Avatar
Engine: 355, 355
i already bought the 200cc heads.
Old Jun 19, 2005 | 12:33 AM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
I would not put a TPI setup on top of heads that big.
Id say to use whatever springs that GM recommends with the Hotcam, but it will probably be something like a 986 Comp. Buy the pushrods last, mock up the valvetrain and use an adjustable pushrod to check what length you need. Either size header will work fine.
Old Jun 19, 2005 | 09:33 AM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
Thats a pretty bad mis-match. The HOT cam doesn't really come on until 3500rpm, TPI starts to give out at about 4500rpm. Thats not much of a range. Now you have large runner heads compounding the problem even more. If I were you I would sell the Edelbrock base, SLP runners, plenum, fuel rails, and AFPR. Keep everything else and install a Stealth Ram Part# HLY-7540 and fuel rails with AFPR Part# HLY-534-186.
You will be much happier.
Old Jun 19, 2005 | 10:14 AM
dharrison's Avatar
Engine: 355, 355
i am going to keep the TPI and i have a carb motor that i can use those heads on if they are that bad a mismatch. the question now is what heads and cam for my TPI? i have a set of world S/R torquers that i could port a little but what is a good roller cam? LPE 211/219 MAYBE? I have run both setups on a dyno2000 silmulator and the original combo was better?
Old Jun 19, 2005 | 12:12 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
In my signature is my current setup. Similiar to what you are doing and with TPI.
Old Jun 19, 2005 | 12:16 PM
dharrison's Avatar
Engine: 355, 355
which trickflow heads are you running?
Frozer!!!
Jan 19, 2024 04:55 PM
Jake_92RS
Jan 28, 2020 10:37 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
