attn RB83L69
Old Sep 8, 2001 | 09:10 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
attn RB83L69
hi, as you remember i was asking questions about my oil burning problem, and my valves not adjusting correctly, well i finally took the motor out of the car, the 2 cylinders that are burning oil have cracked oil rings, but the walls look perfect and barely have a ridge, i also bought some new roller lifters to solve the ticking problem, my question is, what kind of rings do you recommend or anything that i should look for or do while this motor is apart, i'm gonna bring the block to a machine shop to get it honed and cleaned up, also i took off 3 rod bearing caps, but i mixed them up by accident, does this assembly need to be rebalanced in that case? i'm going to have all new bearings put in it, thanks a lot.
86 Camaro with 88 305 LB9 using 86 carb setup, edelbrock performer manifold, 305 S/R Torquer Heads, Hedman Headers, Crane Compucam 2032 edelbrock cat-back, gutted cat, slp underdrive pulley, mallory ignition, 305 h.o dual snorkel air cleaner, hypertech thermomaster chip,160 degree thermostat, 5-speed, 3.23 posi
95 Beretta Z26, 3100 V6, 4 Speed auto, stock
Old Sep 8, 2001 | 11:45 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The standard Sealed Power chrome-moly rings are a pretty good product, as are TRW rings. The Sealed Power number is E-356K, in whatever oversize if necessary, IIRC. Definitely make sure the piston ring grooves aren't damaged; the rings should fit tight in them, no more than .005" of gap between the ring and the groove.
You should be able to get the rod caps matched back up if you have only 3, there aren't that many possibilities. They won't mate perfectly and make a smooth round bore unless they are matched with the right rod, so it should be easy to tell. As long as you don't replace anything or do anything else that would change the weight, you should need re-balancing.
Besides all the usual stuff about tearing down and re-assembling a motor, like making sure everything is as clean as possible etc., there's nothing else special I can think of that you would need to do. Maybe check the crank real carefully for wear and polish it, and of course try to figure out why the rings failed; that sounds kind of like an assembly issue though.
ICON Motorsports
Old Sep 8, 2001 | 11:59 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
ok, well the motor has 70k on it, it's strange that the rings cracked too, the motor was sitting for about a year unstarted when i got it, so i dunno if that has anything to do with it, and yes 1 of the pistons the groove got chewed up, but the other broke in half and overlapped, so the groove on that is okay, i'm going to take it to a machine shop for cleaning and everything else. Thanx
R3500
Aug 24, 2015 09:05 AM
zippinz
Jul 10, 2007 11:14 PM
NEEDAZ
Car Audio
Jun 23, 2005 07:15 AM
blue305rs
Jul 8, 2003 07:04 PM
