What causes high HC's???
Old Sep 8, 2001 | 07:10 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
I was just thinking about my last smog check and I had literally 0.00 NoX and 0.01 on the other measurement(forgot the name ).
Anyways, my Hydrocarbons were a little high and i was wondering if this was related to me getting below average MPG....so, isn't HC's like unburned fuel??? Could my injectors be leaking?
-Dan
-1990 3.1L RS
-Mods? no
-Slow? yes
-Currently collecting parts for T5 swap
Old Sep 8, 2001 | 07:34 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
hc is unburned fuel. Could be several things. Incomplete combustion misfiring plugwires/plugs is the most common cause.
Old Sep 9, 2001 | 12:00 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Right... high HC [i]and[/c] high CO indicates a rich mixture, i.e. too much fuel for the amount of air. High HCs by themselves along with low CO numbers indicates that when combustion does occur, it's in the right proportions, but unburned fuel is passing through the engine to the exhaust. In a stock motor (no big cam, no blower) this is usually caused by an ignition miss.
ICON Motorsports
Old Sep 9, 2001 | 12:11 AM
Engine: LH0 3.1L
RB83L69,
Ok, what i've observed is that when my engine is cold/warm it runs fine. When it gets up around 220 i notice my tach move up and down EVER SO SLIGHTLY. Not much, but it's visable and audible. I have new plugs/wires/cap/rotor....what should i replace?? Ignition module?
Oh, and a miss wouldn't explain poor MPG's....right?
-Dan
-1990 3.1L RS
-Mods? no
-Slow? yes
sp8ty
South East Region
Sep 24, 2018 03:55 PM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Zell1luk
Sep 29, 2015 10:36 AM
