Sluggish camaro, timing perhaps? Help!
Old Jun 19, 2005 | 09:57 PM
k's89rs's Avatar
Car: 89 rs, bmw 325 is
Engine: 360 (.060) 2.5L inline six
Transmission: 700r4, 5-speed
Axle/Gears: 9 bolt 3.08 3.? limited slip
Ok i have a lo3 700r4 and 2.73 peg leg. Now my car has some miles on it odometer says 345,000 ( turns every 1/10 of a mile), more like 140,000. Ive been noticing lately that it lags quite a bit. My guess is timing. Now, i dont have many mods done to it, just shorty headers and a muffler, no cat, and a open element air cleaner. Awhile back i tore the intake off to replace some gaskets and didnt know what to set the timing at. I looked, and from the factory it should be set at 0 degrees. I dont know waht is up with it. It lags until about 2500 rpm and then it picks up. Also when i start it up in the morning, the rpms fluctuate real quick. it will go to 1000 then almost choke, then do it again, and for a third time too. Im just wondering what it is because my sister has the same driveline as me only with a flowmaster and hers seems way more responsive. Also before i make myslef look like a fool can someone explain the principle of timing to me?
Kent
Old Jun 19, 2005 | 10:07 PM
pellmanm's Avatar
Car: 1989 GTA
Engine: 383 Fuel Injected
Transmission: Pro-Street 700-R4 by Pro-built
Axle/Gears: Moser 12 bolt w/posi
Make sure that the est wire is disconnected, then set the timing at whatever it needs to be, be sure to plug it back in.
Old Jun 20, 2005 | 09:10 AM
k's89rs's Avatar
Is that the brown wire? Ive been pulling the brown wire to do my timing.
Old Jun 20, 2005 | 09:47 PM
pellmanm's Avatar
Car: 1989 GTA
It is the tan/white wire.
Old Jun 26, 2005 | 12:17 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
WEll you just solved your problem. It's a 140k mile lo3 with a small rearend.
Old Jun 26, 2005 | 04:34 PM
k's89rs's Avatar
i know the engine has some miles on it but it shouldnt be this slow. i just got back home from doing a run with my gtech ( i know its not that accurate but) and i ran an 11.42 in the 1/8th. It has been reading pretty close to what i have run before a 10.5 on the actual track. when i pin it it doesnt have the low end like it should. it has to be timing. that is the only thing i have done to it that would effect its performance negatively.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Linson
Aug 21, 2015 02:12 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
