Differences between RTV?
Old Sep 8, 2001 | 07:18 PM
mcconahay37's Avatar
What are the differences between the different kinds of RTV and their proper applications? I always use the blue kind, but what about black, clear, and orange?
Old Sep 8, 2001 | 07:48 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Orange is refered to as red (no idea why) It's used as high temp. It won't dry out and crack in high temp areas.
The other three have their own properties. Some will stay soft and plyable. Others are sensor safe for use in emision controlled cars.
The majority of the time I use "red" for anything I do that needs some silicone except if I need a sensor safe silicon.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Sep 8, 2001 | 08:39 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
The best stuff for "all around use" is the GM Silicone Sealant (RTV). Its the best stuff, and has a metallic look to it to blend in, unlike the bright colors that tend to look sloppy.
I also tend to see less leaks w/ the GM sealant as compared to the "others".
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old Sep 9, 2001 | 02:08 PM
Thanks guys. I was reading the backs of the packages, and they all seemed to say the same thing, so thanks for clearing that up.
Old Sep 9, 2001 | 04:41 PM
ede's Avatar
ede
only 2 i use and the most costly are ultracopper and ultragrey. the ultracopper is for hig temps and the ultragrey is for everything else. as for the differances i don't know but i know what i like and what works for me.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
69GTOby
Apr 18, 2016 02:34 PM
BAMiller
Sep 14, 2015 06:38 PM
Numbah-1
Sep 12, 2015 08:57 PM
J.C. Denton
Sep 8, 2015 05:35 PM
greenyone
Sep 2, 2015 03:39 PM
