no spark, changed almos everithing and still no spark...I dont lnow what to do
Old Jun 20, 2005 | 05:05 PM
dandealer's Avatar
Car: pontiac trans am
Engine: 2.8
Transmission: auto 4 with overdrive
Hi, I hope someone can help me with my problem:
I own a 1988 2.8 firebird, a month ago it sudenly stops to run, it just started about 5 or 6 times but at last it wont start any more. after check I realized there is no spark in spark plugs nor in the coil. I had changed the coil, the distributor cap+rotor and the ignition control module and still no spark. I had checked for error codes in the ecm and it only flashes code 12.
In the past the car wont start but after a day or two it runs without problems. As I'm in spain and here this cars are rare I cannot take it to a mechanic cause I had alredy done and they returned the car to me without solve my problem.
Well thanks in advance, i hope someone can help me.
Old Jun 20, 2005 | 05:07 PM
dandealer's Avatar
Engine: 2.8
btw, when I say in the past it wont start I mean that some times the car wont start for one or two days, usually It starts with no problem.
Old Jun 20, 2005 | 08:29 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
ignition module?
Old Jun 20, 2005 | 10:24 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
or pickup coil.....
Old Jun 21, 2005 | 12:58 AM
johnfwz28's Avatar
Car: 1987 Z28 Camaro
Engine: 5.7L TPI
no spark!
check the ignition fuse!!!
Old Jun 21, 2005 | 05:29 AM
dandealer's Avatar
Engine: 2.8
I have replaced the ignition coil and the pickup module for brand new ones without any result.
If the ignition fuse is located unther the drive wheel I have checked and there is no blown fuse if not please tell me where to find it and I will check.
Thanks for all your help, I cannot check anything till saturday, but I think that if I go to the car with many ideas maybe one is the right one:P
Old Jun 21, 2005 | 11:28 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Do you know if the distributor is spinning when you crank over the starter?
Old Jun 21, 2005 | 11:55 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
As VernW said, remove the distributor cap, and crank the engine the rotor should turn, if not, it's the timing chain, or something that's keeping the timing gears from turning, or dsitributor gear has sheared the gear locking pin.
Also, you didn't say if you checked for 12volts at the distributor pink wire with the key on.
Do one thing at a time, and you'll find the problem.
Old Jun 21, 2005 | 04:07 PM
dandealer's Avatar
Engine: 2.8
the distributor spins when crank the engine and there are 12 volts in the pink wire when key in accesory.
Old Jun 21, 2005 | 04:20 PM
vernw's Avatar
How about when "ON"?
Old Jun 21, 2005 | 04:23 PM
dandealer's Avatar
Engine: 2.8
add to my check list for fryday
Old Jun 21, 2005 | 07:34 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
12volts when ON/RUN/START
Old Jun 23, 2005 | 04:42 PM
dandealer's Avatar
Engine: 2.8
12 volts confirmed
BTW someone tells me thet white wire in coil is trigger and coil should fire if I ground it, I have done it and the coil not fires but I have spark on the wire I use to ground.
Old Oct 14, 2005 | 05:58 PM
dandealer's Avatar
Engine: 2.8
Spark Plug problem solved
Hi I just forgot about this post,browsing the forums I rediscovered it, I finally found the problem with the spark, it was the pickup coil inside the distributor, it was broken. I change the distributor (I just cannot find the pickup coil itself) and it starts now. After that i had some more troubles but thats a diferent story. Hope that if someone have ever a similar problem this helps him to fix it.
Thanks a lot for your help.
eightsixseven
Dec 16, 2024 01:50 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
mddaniel
Sep 8, 2015 05:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
