ECM CODE 34
Old Sep 9, 2001 | 05:22 PM
JOHN/88IROCZ's Avatar
ECM CODE 34
WHAT WILL CAUSE A ECM CODE #34 AND HOW CAN I REPAIR THIS SO TH CODE WILL DISAPPEAR? WHEN MY SERVICE ENGINE LIGHT COMES ON THE CAR RUNS LIKE THE TIMEING IS RETARDED ALOT. I CAN KILL THE ENGINE, RESTART IT, USUALY THE SERVICE ENGINE LIGHT WILL GO OFF AND THE CAR WILL RETURN TO NORMAL PERFORMANCE.WHEN I READ THE ECM CODES IT SHOWED ME (12,34,12)
ANY HELP WILL BE GREATLY APPRECIATED
JOHN
Old Sep 9, 2001 | 06:31 PM
rezinn's Avatar
Thats a MAF code, you may need to replace the relays or even the sensor.. try taking the sensor out and cleaning it off with carb cleaner, and cleaning the relay connections off.
If it still runs bad, disconenct the sensor and try running, if your car runs alright the sensor or relays are bad. Replace the relays first, they are like 10 bucks each.. A remanufactured sensor shold be about $135, new $450.
Old Sep 9, 2001 | 07:10 PM
I FOR GOT TO MENTION I REMOVED THE SCREEN ON THE MAF. NO OTHER MODS TO TH MAF. COULD THIS BE THE PROBLEM
Old Sep 9, 2001 | 07:34 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
<font face="Verdana, Arial" size="2">Originally posted by JOHN/88IROCZ:
I FOR GOT TO MENTION I REMOVED THE SCREEN ON THE MAF. NO OTHER MODS TO TH MAF. COULD THIS BE THE PROBLEM</font>
Could be. The code is low detected airflow from the MAF. It could be that your tubing is loose post MAF, your power relay could be bad, or ultimately your MAF. Do me a favor though... DON'T squirt that thing with carb cleaner. It's a good way to ruin it.
"Question with boldness even the existence of a *** ; because, if there be one, he must more approve of the homage of reason, than that of blind-folded fear."
-Thomas Jefferson
Old Sep 9, 2001 | 10:05 PM
Vader's Avatar
You KNOW what I'm thinking....
Later,
Vader
"Click - Click - BOOM!"
Adobe Acrobat Reader
[This message has been edited by Vader (edited September 09, 2001).]
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
eustodp
Sep 20, 2015 05:09 PM
Reese-J
Sep 14, 2015 02:43 PM
RyanJB
Sep 2, 2015 01:27 PM
