383 oil pan
Old Jun 20, 2005 | 07:45 PM
tompumped's Avatar
Car: 88 firebird
Engine: 355
Transmission: t-5
Axle/Gears: 9 bolt 3.91
383 oil pan
Hi, i'm looking for an aftermarket oil pan with a crank scraper and/or windage tray. It' a one peice rear main. It's going in a third gen. I'm looking to spend about 150. I think it's a 5.7 rod because there is no dimples on the stock pan for crank clearance.
Old Jun 21, 2005 | 11:30 AM
Wayne's 383Iroc's Avatar
Car: 88 IROC
Engine: 383
My stock pan worked with 6" rods after it was modified a little. Some of the aftermarket pans will not clear the Y pipe. I did have the morso pan and it fit good ( no scraper or tray over $150) Summit has several. hope it helps
Old Jun 21, 2005 | 12:52 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
You can certainly find a pan for $150, but you are definitely not going to get a scrapper and tray for that amount..... SLP and Conton offer 6qt (or more) pans with trays for 1pc rear seal, but go for $225 to $350.
Old Jun 21, 2005 | 01:17 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
Search for Milodon's circle track or "claimer" oil pans at summit or Jegs. They fit 1-pc seals and have a nice windage tray at the bottom built right in.
part number is 31501
price is $124.99 IIRC
Old Jun 21, 2005 | 04:42 PM
tompumped's Avatar
Car: 88 firebird
Engine: 355
Transmission: t-5
thanks for the replies everyone, much appreciated
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
