Rear end bolt torque specs
Old Sep 6, 2001 | 03:19 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
What are the bolt torque specs for the pinion nut and the carrier bolts for a GM 7.5" rear? I posted this on the Transmission and Rear end board and got no responses. Thanks
89 Transam GTA, 350TPI, auto, 3.27 rear, dual cats, gray.
Magnaflow cat-back,
K&N open element,
Best E.T. 14.63@95mph
Old Sep 6, 2001 | 03:41 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Carrier bolts are about 60 ft-lbs. Pinion nut doesn't have a torque spec, you should expect something in the 150-180 ft-lbs neighborhood, you torque it for correct bearing preload by way of crushing the crush sleeve which is only good for one tightening. You throw it away and put in another if it's not new.
ICON Motorsports
Old Sep 6, 2001 | 04:04 PM
ede's Avatar
ede
pinion bearing preload with new bearings is 20-25 in/lbs
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Sep 9, 2001 | 10:20 PM
Car: '89 GTA
Engine: ZZ6TPI
I replaces the crush sleve and the input seal. The bearings were in great shape. 20in/lbs seems kinda light. Are you sure it's not more like 20-30 ft/lbs.?
Magnaflow cat-back,
K&N open element,
Old Sep 9, 2001 | 11:04 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The idea is, you torque the pinion nut until it takes that many inch-ponuds to turn the pinion. You're trying to tighten the nut just past the point at which all the play betwen the bearings gets taken up. Like I said earlier, expect something in the neighborhood of 150 ft-lbs on the nut by the time you get the crush sleeve crushed to the right point.
ICON Motorsports
Old Sep 10, 2001 | 10:37 AM
Car: '89 GTA
Engine: ZZ6TPI
ok, i get it now. Thanks for your help.
Magnaflow cat-back,
K&N open element,
Old Jul 4, 2024 | 11:23 PM
Jarhead513's Avatar
Re: Rear end bolt torque specs
I have a 2000 firebird with a 10 bolt rear end and noticed a humming more grinding from the rear end. Ill be honest im morenof a mopar guy and just recently bought it and when i looked underneath itnwas leaking gear oil from the yolk going into the pinion/pumpkin i guess. Theres a gap between the two and the nut looks like its backing out possibly it only has about two or three full threads left. My question is is there a certain distance the nut needs to be tightened for it to sit and align everything in the pumpkin correctly?
Old Jul 5, 2024 | 11:23 AM
I think that was covered in the above post.
Problem you may have is, the crush sleeve, which is what the nut tightens up against, may already be crushed beyond the proper point. In which case the only thing holding the nut in place is its nylock feature. If that's how it is, it will never stay tight, until the crush sleeve is replaced. You can try though; pop the axles and the carrier out, and try to tighten the nut until it takes 25 in-lb or so to turn the pinion. The locknut takes probably no more than 25 or 30 ft-lbs to overcome the lock, so if you have to put LOTS of torque on it to get the right bearing preload (like, over 100 ft-lbs), you're probably crushing the crush sleeve, and your odds of success are better.
Make yourself a tool like this to hold the pinion still while you tighten the nut with a long breaker bar and a 1¼" or 32mm socket.
It's about a 3' or 4' long piece of 1½" wide bar stock from the hardware store. Drill the holes near the edge so it doesn't interfere with the socket getting onto the nut.
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
