What is the best way to empty fuel tank?
Old Sep 10, 2001 | 02:13 AM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Running it dry is not an option since the engine is on a stand next to the car. I have some old gas in the tank and I don't want to run it through my new injectors. Can I run power to the pump and drain it through the fuel lines?
92Z28
89GTA
Old Sep 10, 2001 | 02:31 AM
Jester's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Acceld Z:
</font>
Sure. The easiest way to do that it find the fuel pump relay, unplug it, and jump the 2 terminals with the thicker wires coming out of them with a section of wire or something. Just keep an eye on it, make sure you don't keep running the pump after it stops putting out gas. Expect it to take awhile if you're using the stock pump..it goes slow.
Old Sep 10, 2001 | 03:48 PM
Bjase's Avatar
Car: 88 IROC
I put a squeaze type siphon pump meant for kerosene and a length of silicone tubing down the gas filler. It left under a gallon in the tank.
88 IROC with cobbled together (not by me)drivetrain, 86 (?) TPI unit on an '83 305,CE subframe connectors, Edelbrock strut tower brace, polygraphite bushings all around...it handles like a dream, but man is it hard to push!!
Ghettobird52
Jul 5, 2024 11:18 PM
jbates346
Car Audio
25
Jun 10, 2020 08:27 PM
mustangman65_79
Apr 14, 2017 05:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Glowsock
Aug 26, 2015 12:28 AM
