Beefing up a LO3?? Mod Question
Old Sep 10, 2001 | 06:48 PM
LowStyle's Avatar
Ok this might seem like alot to do all at once but...can I put a prom chip in my 92 Camaro RS? Would you guys recommend a hypertech or jet? Also I am going to get free flow cat converter and flows? And the other question I have a 305 TBI V-8 Is there anyway I can convert that to a 305 TPI with out a lot of hassle? How hard or easy would it be and cost wise?
Old Sep 10, 2001 | 07:05 PM
dtpmike's Avatar
no there is no easy way to convert to TPI you have to swap the entire computer and harness. Its a hassle.
Old Sep 10, 2001 | 08:43 PM
Vader's Avatar
LS,
Consider yourself lucky to have the L03 instead of the LG4. At least you have flat pistons and decent valves.
The fuel system is not your problem. The TPI may provide a little better low end torque (O.K., quite a little better) but the TBI will run the engine with more power on the higher RPM end of the scale. Your biggest impediments to power are teh exhaust, cam profile, and head design. You can do a lot with just a cam kit and some home porting of the heads. Of course, the different cam will require a different PROM to run correctly, but the HyperTech isn't the answer. It is only designed to provide a richer mixture and better spark advance at the mid- and upper-end of the throttle range. A custom would be your best bet.
For some good suggestions oon how to maximize your current setup, check the Tech Articles at the front of the site.
Later,
Vader
"Click - Click - BOOM! Saliva - American Outlaw"
Adobe Acrobat Reader
Frozer!!!
Jan 19, 2024 04:55 PM
ydnar417
Sep 23, 2015 05:57 AM
haps
Interior Parts Wanted
Sep 8, 2015 10:15 AM
lt1z350
Aug 28, 2015 05:57 AM
redmaroz
Aug 16, 2015 11:40 PM
