Can I re-use these?
Can I re-use these?
I was tearing down my old 305, and I was wondering if these parts can be re-used:
This head seems to have a hole in it... that should be ok right?
This rod bearing seems to be missing the tab that holds it in place... that's no big deal I assume
[I AM BEING SARCASTIC]
Car: yep
Engine: uhuh
Transmission: sure does
The bearing will be OK as long as you re-use the egg-shaped rod that it came from...
Just fill the hole in the head with RTV.
Any other questions..
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
[This message has been edited by Engineboy (edited September 10, 2001).]
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I never had any bad bearings but I punched a hole bigger than that in a 781 big block head. I should scan the pic of the piston some day. The head of an intake valve is sticking straight up out of the top of the piston.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.546
Car: 1992 Z28
Engine: 355
I have a coffee can full of piston skirts and a few bearings that you could shave with. I learned to shut it down when it starts to knock from that episode.
92Z28
89GTA
92Z28
89GTA
brodyscamaro
Mar 31, 2003 06:40 PM
