Another bad rumor, or is true? Rubbing alcohol in gas tank?
Old Sep 8, 2001 | 12:22 AM
Xenodrgn's Avatar
Ok, this sprouted from the post about not being to pass emmissions...
https://www.thirdgen.org/messgboard/...ML/013357.html
Is it true that if you pour a bottle of rubbing alcohol in the tank that it'll clean things out? Or is this just another old wives tale? I'd really like to know...
If it's true, what size bottle are we talking about? the $.69 bottle or the more expensive big one?
Thanks for the time, and if this is just a junk joke, don't flame me for it, I'm learning...
Old Sep 8, 2001 | 12:31 AM
rezinn's Avatar
Make sure to ask if you do it before emissions, or when you are going.. It could temporarily worsen your emissions if it is the same kind of thing as those additives.
Old Sep 8, 2001 | 01:47 AM
One Eyed Jack's Avatar
shouldn't hurt too bad. I mean, its not corrosive, and as long as you get the bottle thats NOT diluted in water (haha) it probably wouldnt hurt anything. Just go buy a carb/FI cleaner at the gas station for a dollar.
Old Sep 8, 2001 | 10:31 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
If you read the labels of all those emission cure bottles they contain alcohol, this is just a cheaper way of going about it. I'm not saying that this will gaurantee you to pass, but it has lowered my readings in the past, and also don't just drive straight to emissions, drive around for atleast 20 mins.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Sep 8, 2001 | 12:45 PM
Vader's Avatar
Anybody ever hear of gasohol?
Later,
Vader
"Click - Click - BOOM!"
Adobe Acrobat Reader
Old Sep 8, 2001 | 02:19 PM
82camaro's Avatar
Car: 82 camaro SC
Good call Vader. Around here, everything above 87 octane is 10 percent alcohol(keeps the farmers happy since its derived from corn). It's actually nice because it 90 octane costs the same as 87. The 90(with 10 percent alcohol), lets me run a little bit more timing. I also have to jet it a little bit fatter to compensate for the alcohol. It a 16 gallon tank, you would need 1.6 gallons of alcohol to make it 10 percent.
Alcohol can be harmful on the fuel system(attacks rubber stuff). More than 10 percent could cause problems.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
[This message has been edited by 82camaro (edited September 08, 2001).]
Old Sep 8, 2001 | 03:04 PM
IROC&ROLL
Guest
Posts: n/a
The alcohol sold in stores for $.69 is 70%isopropyl alcohol and 30% water. I don't think it is the same as methyl alcohol... but I've been known to be wrong once or twice before.
I've read several articles in auto magazines that say octane booster is good for a noticable decrease in emissions. I don't have tailpipe sniffing in my area yet... but it's coming as soon as the county next to mine fails to meet standards again.
Old Sep 8, 2001 | 09:03 PM
Xenodrgn's Avatar
Ahh, ok... I was under the impression that he was talking about the store stuff... It had never occured to me that he ment methyl... or gasohol... Thanks guys...
1985 Camaro SC - 2.8L, auto.
http://www.xenodrgn.f2s.com/Frontright.jpg
Old Sep 11, 2001 | 03:31 AM
evilho7810's Avatar
I know that denatured alcohal works.
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Andrew6.688
Dec 13, 2015 10:59 AM
mustangman65_79
Sep 1, 2015 03:51 PM
AkDrifted
Aug 17, 2015 07:45 PM
