Uh oh starter says only 10.0CR...
Old Jun 23, 2005 | 10:03 PM
ChevyRacer's Avatar
Car: 86 Camaro Iroc-Z
Engine: 355 TPI
Well my compression ratio is most likely going to be much higher then 10.0:1. More like 10.6:1 if I am lucky.
Will this actually hurt my brand new starter? It has a lifetime warrantee but I surely would hate to go somewhere and have to call AAA because my starter went out but it has a lifetime warrantee.
My set-up is a 350, Summit stage 2 rods, stock crank reground and polished, -8cc hypereutectic pistons, and ported, without a valve job, 601 casting heads. I estimate the same stock cc ratio as stock 305 castings (54cc).
If you ask why such a poor solution in heads well, I am going to upgrade soon enough just a 350 was the first motor I found and I had 4 sets of heads but these were the cleanest and all. I had a set of 083 castings that were brand new and the valves were performance sets, I just didn't like them due to other reasons. I’ll be getting aluminum heads sooner then later.
AM I going to blow my starter? The head gasket is a .031 thickness composite gasket.
Without even being started and no sparkplugs, you can hear the air come out of the spark plug holes. It really has that much air to move.
So is my starter ok?
Old Jun 23, 2005 | 10:59 PM
pellmanm's Avatar
Car: 1989 GTA
Engine: 383 Fuel Injected
Transmission: Pro-Street 700-R4 by Pro-built
Axle/Gears: Moser 12 bolt w/posi
Your starter should be fine, i have a 10.5:1 compression 461 cubic inch BBC in my truck, and the stock style starter works fine, it is a starter off a small block, but i believe they are all the same anyways. If you are worried about it, you could always get a gear reduction starter.
Old Jun 23, 2005 | 11:35 PM
ChevyRacer's Avatar
Engine: 355 TPI
awesome thanks very much.
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
