Need answer QUICK (ebay) about HEADS
Old Sep 11, 2001 | 08:49 PM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Transmission: TH700R4
Hey guys,
does anyone know 100% for sure if these heads will work for an 86 305TPI???
http://cgi.ebay.com/ebaymotors/aw-cg...item=595129424
Thanks!
Ken
1986 IROC-Z Conv't
17x9.5 TT II's w/ 275/40x17's, BMR stb, Lakewood APR, Jamex 1.5" Lowering Springs
ChevyKen's Cars
Administrator @ ChevyWorld.net
Old Sep 11, 2001 | 09:17 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
I have a set of B2L heads that will work great on your 305. They're cheap and they include just about everything you would need to swap them in. Did you get that exhaust manifold stud out yet?
92Z28
89GTA
Old Sep 11, 2001 | 09:31 PM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Hi there,
excuse my ignorance, but what are B2L heads..?
And no, I haven't gotten it out yet. The heads are still in the car - but Im exploring the possibilities of another set of heads right now. I haven't decided what to do yet as Im trying to pull together all the info on the cost of everything.
I found the ebay auction above a little bit TOO late so there was not enough time to get the needed info straight - so Im still looking. Any info about suitable heads are very much appreciated!
Ken
Old Sep 12, 2001 | 02:12 PM
L98IROCZ89's Avatar
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
Well L98 is the code for the 350 ENGINE and B2L is the code for the performance package that includes the 350. Sometimes when the car has a 350 you will see B2L/L98 for the RPO code.
I am assuming that he means B2L/L98 f-body (iron) heads, but i could be wrong.
1989 Chevrolet Camaro IROC-Z
L98 - 350c.i. TPI, rebuilt 700R4 auto w/shift kit, Dual catalyst Monza PaceSetter Cat-Back, SLP 1 5/8 Coated Headers, 3.23 Posi rear, Hypertech chip with 160stat, MSD 6A, Under-Drive pulleys, AFPR, K&N's, !Air Box w/ Ram Air, moddified MAF, !TB Coolant, Spohn Dual Cat SubFrame Connectors, Alarm, Keyless entry, remote starter, 92 Z28 AeroWing, Brand New Paint (6/21/01)
Future: ZZ4 TPI w/EGR, T56, 3.42 or 3.73, Spohn strut tower brace and LCA's
1989 Chevrolet Celebrity Eurosport
2.8 MPFI, no mods
225,000 miles and still ticking!
More info and pics on my webpage:http://go.to/iroc-z
AOL IMer: GPA 0point0
Old Sep 12, 2001 | 02:26 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I fail to see how 64cc chamber L98 heads would work "great" on a 305 designed for 58cc chambers. Perhaps with shaving, but it's still not a match made in heaven.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 CC system w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker 2055 headers, 3" Catco cat & 3" catback, restalled TC, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Sep 12, 2001 | 02:43 PM
Drakar's Avatar
Could always get the vette L98 heads 58cc, and that would keep compression the same.
1989 Trans Am GTA, L98 5.7L TPI, TH700-R4, T-Tops, dual cats, 9-bolt rear, 3.27, Dynomax muffler, K&N
1992 Camaro RS, LO3 5.0L TBI, T-5, T-Tops, 3.08, L69 Dual Snorkel, K&N - Sold
Honda engines ROCK, I have one on my lawn mower but I still have to push it.
Old Sep 12, 2001 | 03:03 PM
Dirtybird355's Avatar
See my post about L-98 vs 882 cylinder heads. I was considering getting the L-98 ones to replace my 882's but i was informed that my 882 heads actually flow a lot better than i thought. The nice thing about 882 heads is that they came an a lot of small blocks through the 70's, and at least around here, they're easy to find in junkyards. Way cheaper than L-98 heads too.
Old Sep 12, 2001 | 11:08 PM
85transamtpi's Avatar
You cant use anything with 2.02/1.60 valves...I think they dont clear the bore on a 305. Im not sure what valves come on L98 heads, but after the work needed to keep your compression is done, they would probably cost more than heads designed for a 305. Ive heard good things from people who have used the vette heads, but I hear they require some modifications to fit.
Hope that helps some
peace
Old Sep 12, 2001 | 11:33 PM
rezinn's Avatar
I see that its too late now, but besides having killed your compression, the valves are too big.
lt500r55
Sep 1, 2021 01:30 PM
NinjaNife
Aug 23, 2015 11:49 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
