what's the easiest ways to change spark plugs??
Old Sep 12, 2001 | 10:26 PM
firebird305's Avatar
First off,I want to say that yesterday's attack was a pure act of cowardess,I'm so angry that i want to re-up in the corps again if the call comes,and i can't get in touch w/my nephew,Who doesen't live far from the towers.But,I have faith in my country,Those responsible WILL pay,And i feel in my heart that my nephew is alright.Anyways,I was changeing out my plugs today,And i'm haveing a hard time with the middle plug on the driver's side and the 2 back plugs on the passenger side.I love the performance my headers give,But they sure are hard to get around! What's the best tools to use to get around them,And does anyone have a quick fix for replaceing sparkplugs in our cars?Oh yeah,Before i forget,It's great to see the post from the other devildogs on this board as well as others who served in the other branches of service too,You guys are the best!Thanks!
82 firebird with 305H.O.,Block bored .30 over,Keith black hyperutectic flat top pistons for 10 to 1 compression,Turned crank,Magnafluxed connecting rods,Melling H.V. oil pump,and double roller timeing chain,Ported and shaved heads w/3angle valve job,Z-28springs,Summit push rods and comp cams magnum roller rockers,Ported Edelbrock performer r.p.m.intake,Carter 625 afbcarb,Accell spark plugs,wires,and H.E.I.super coil,Heavy duty cap and rotor,Clevite performance cam with 450-460 inches of lift,Comp cams lifters,700r-4 tranny rebuilt with trans-go rebuild kit,corvette servo,New torQue converter,Flowtech headers,Flowmaster muffler,3.73limited slip rear end,Energy suspension bushings from front to rear,Energy suspension tranny mount,New center link,ball joints,trans-am steering box,ASP power pully.
Old Sep 12, 2001 | 11:05 PM
u r sofa king we tah did's Avatar
i have headers on my 350, i can change all 4 plugs on the drivers side from up top with no problems with a 5/8 spark plug socket, i can change the front two on the passenger side from above the same way, but the two closest to the firewall i have to get them from underneath with a 5/8s open end wrench. i feel you on your venting though. the acts done yesterday were completely uncalled for. innocent people loosing their lives because some terrorist is mad at the US is b.s. if we go to war, you can damn well count on my 19 year old a*s enlisting and fighting for what freedom stands for
Old Sep 12, 2001 | 11:19 PM
Vader's Avatar
305,
Have you tried using a spark plug socket with a regular open or box end wrench on the flats? I've had pretty good luck on #6 & #8 with that combo. The steering shaft couldn't be more convenient for that #5, could it? The socket trick might work there, too. I've had to use several different extenssions to get that one out - one to break it loose, a different one to back it out part way, and no extension to finish the job. And I don't even have headers in the way.
Later,
Vader
Justice and Freedom will Prevail
Old Sep 12, 2001 | 11:29 PM
rezinn's Avatar
Im not sure if your flowtech are as badly designed as my edelbrock, but I can change the spark plugs pretty easily on the drivers side with the aid of an open end wrench.. the passenger side you have to go from beneath, but I use the same 5/8 combination wrench for every plug.
Oh, Vader.. I see you missed this one.. Don't forget the anti seize!
[This message has been edited by rezinn (edited September 12, 2001).]
Old Sep 13, 2001 | 03:32 AM
85 Berl's Avatar
I have the Edelbrocks, too. I can't quite get the open end wrench to line up on the socket, so I use Channel Locks. The passenger side of mine is a real bastard to get out.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
apo_bailon15
Mar 28, 2016 05:20 AM
evilstuie
Feb 28, 2016 03:33 PM
