1990 IROC Won't Fire
Old Jun 27, 2005 | 09:19 AM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
My buddy just completed a motor rebuild and he can't get his 1990 IROC to fire. He checked the module and it's fine. The coil checks out as well. The thing ran good before the motor swap and we must have something miswired or ? It's a speed density motor. He has had the top end off this motor previously and successfully got it back together and running with no problems, so he's no dummy. He feels like it must be something he's overlooking. Any suggestions would be greatly appreciated.
Old Jun 27, 2005 | 11:55 AM
PACMAN007's Avatar
Car: 89 TA, 85 MCSS
Engine: 305 TBI, 305 TPI
Transmission: T5, T5 WC
I'd check the grounds to the cylinder heads... on my 89 Trans Am there were two going to each side... I had the same problem with the car not firing. If that checks out, I would start with the basics, whats getting power, what isnt, is the timing right, is it getting fuel, etc...
Frozer!!!
Jan 19, 2024 04:55 PM
Derick15
Sep 17, 2016 05:28 PM
justin57
Aug 20, 2015 07:05 PM
Dialed_In
Aug 20, 2015 01:45 PM
mustangman65_79
Aug 11, 2015 03:17 PM
