For new rockers do I need to change my push rods?
Old Jun 27, 2005 | 02:51 PM
tojan19's Avatar
Car: 85 Tojan
Engine: ZZ4
Axle/Gears: 9", 3.50
I'm swapping the stock 1.5 rockers on my ZZ4 for some GMPP full roller 1.6 ratio rockers. Do I need to worry about push rod length changing? Thanks
Old Jun 27, 2005 | 05:56 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
No.
Old Jun 3, 2007 | 08:49 PM
twolfe's Avatar
Car: 91z28
Engine: 5.7 l98
Transmission: AT :(
Re: For new rockers do I need to change my push rods?
im going to a 1.6 proform full roller from stock 1.5. is this the same issue as above?
just use the stock 7.2's?
-Tony
Old Jun 3, 2007 | 08:52 PM
Damon's Avatar
Most rockers the pushrod cup is in the same position as stock, regardless of what the outward appearance of the rocker might be.
In most cases, the answer is no, you don't need different length sticks if rocker arms are the only change you are making.
Old Jun 3, 2007 | 08:54 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Yes, same case. No, no need for different pushrods.
If you're going to a bigger cam as well, maybe measure your pushrod length, but you should be VERY close to what you need with the stock length.
Old Jun 3, 2007 | 09:04 PM
twolfe's Avatar
Car: 91z28
Engine: 5.7 l98
Transmission: AT :(
Thanks fella's, I thought that they would use the same length, but had a little bit of uncertanty. Thanks for clearing that up.
-Tony
customblackbird
Aug 15, 2021 10:16 PM
Reborn756
Sep 4, 2015 03:42 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
LT1Formula
Aug 20, 2015 09:36 PM
