Can plugging the line to the charcoal cannister make my fuel leak worse?
Old Sep 13, 2001 | 03:34 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The fuel line attached to the front-facing side of my FPR leaks on occasion. Mostly when I first start the car. It seems that since I plugged the line that used to go to my charcoal cannister (it used to be open but I got a gas smell from it), my fuel leak has gotten worse. Since the fuel rail is pressurized anyway, I don't see how capping that other line made a difference, but I did notice that I really hear air rushing into (or out of?) the tank when I open the gas cap now. Could the two events be related?
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Sep 13, 2001 | 04:33 PM
breathment's Avatar
why not fix the fuel hose, before your car blows up, then it will fix all ur problems
but as far as the charcoal cannistor, it which hose did u plug, cause isn't there a few different ones? if i remember correctly, doesn't one goto engine vac source, fuel tank, and maybe another one.. im not sure,
but definatly try to fix ur fuel lines
- David
88' GTA 5.7L TPI MODS---&gt; air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
Old Sep 13, 2001 | 09:12 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
As the above post stated...fix the fuel leaks
The O rings in there are like a buck a piece at the dealer..if that.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old Sep 14, 2001 | 09:30 AM
Jim85IROC's Avatar
I've replaced the o-ring a few times. Right now i've got an oversized o-ring in there and it still leaks intermittantly. I know I should replace the whole fuel rail, but frankly I'm burried up to my *** in car repairs. I haven't had a free weekend in 3 months. I don't know when I'll find the time to remove the whole top half of the motor (including valve covers to get those damned runners off) in order to change my fuel rail.
Anyway, to clarify on my charcoal cannister issue, I removed it a few years ago when I swapped motors. For a while I just had tape over the line from the tank, and recently I finally capped it off. Last night I took the cap off of it and the car didn't leak any gas today. Don't know if it just decided not to leak or if it's related though.
The IROC Homepage
specialized
Jun 18, 2022 09:26 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
AkDrifted
Aug 17, 2015 07:45 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
Kaweh
Aug 9, 2015 02:54 PM
